1974 240d wiper park position - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-15-2010, 07:53 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1974 240D
Thumbs up 1974 240d wiper park position
I just replaced my wiper motor and my wipers are parking in a vertical position, I have searched the forums and I couldn't find anything. Any help would be great!! Thanks
1974 240Dusty is offline
post #2 of 3 (permalink) Old 02-16-2010, 06:08 AM
Date registered: Nov 2009
Vehicle: 1972 280se 4.5 Silver/Maroon
the wiper arms are adjustable. At the base of the arm there is a nut, might be under a cap. While wipers are off loosen the nut , put wiper where you want it , tighten it down.
marcedesbenz is offline
post #3 of 3 (permalink) Old 02-16-2010, 08:19 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
If all is operable then the park position is a part of the wiper motor assy. Run the motor with the arm disconnected from the tapered shaft of the motor. When the motor parks after switching off at the switch the arm should be installed with the blades in the proper parked position. Changing the arm length will make the two arm out of sequence.
Bill A is offline
    1974 240d wiper relay 1974 240Dusty Vintage Mercedes-Benz 7 02-15-2010 07:30 PM
    how dose one change the windshield wiper rest/park position? jezbraker W202 C-Class 6 02-12-2010 10:30 PM
    1974 240d wiper problem 1974 240Dusty Vintage Mercedes-Benz 0 01-23-2010 07:05 PM
    My new (old) 1974 240D onefew General Mercedes-Benz 2 09-05-2009 10:29 PM
    1974 240D 24td Vintage Mercedes-Benz 19 04-13-2009 12:18 PM
