Stock, progressive or sport springs for my 5.0 W111 Coupe? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 02-13-2010, 07:33 AM Thread Starter
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Once my 5.0 engine + 5 speed manual gearbox drivetrain and LSD 3.27 rear axle are ready for install, this will be the time to upgrade my suspension as every thing will be out of the car by then.
Coxracing and SL Market are offering progressive and sport springs:
Mercedes Front End Parts
Sport Springs for Mercedes-Benz SL and Sedans
This car will essentially be a driver, so it should retain enough comfort on long distance trips. But I also want to occasionally get the best of my additional horsepower on track days. So, I’m looking for the best compromise. I was told sport springs may be a bit too harsh on long distance trips. Progressive springs look quite appealing to me as I’m told comfort is retained in normal use but sprigs get stiffer when needed. Or should I just keep my stock springs and fit stiffer shocks?
Thanks in advance for sharing opinions and experience!
GGR is offline
post #2 of 6 (permalink) Old 02-13-2010, 10:33 AM
Date registered: Aug 2006
Vehicle: 1992 300CE
Youre asking for two totally different things.
ronald7410 is offline
post #3 of 6 (permalink) Old 02-13-2010, 04:36 PM
BenzWorld Elitist
Marsden's Avatar
Vehicle: Mercedes-Benz
Quoted: 453 Post(s)
Wow on that drive train. Where can I read more about what you've done??
Marsden is offline
post #4 of 6 (permalink) Old 02-13-2010, 04:55 PM Thread Starter
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Well, it's a bit scattered all over the place. A good deal of it is in the "Budget EFI" thread in the W126 forum. Some also here: http://www.benzworld.org/forums/w126...ml#post3938768
since then I took the trans out and am in the middle of transforming into a 5 speed.
GGR is offline
post #5 of 6 (permalink) Old 02-15-2010, 01:36 PM
Date registered: Apr 2009
Vehicle: Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
Hi, as you know I am looking for the same thinks for my 3.5 5-speed coupe but I decided for the moment to stay with the original 3.5 springs, lower them like AMG did (if I remember wright 1/2 circle in front and 3/4 in rear so it would come down 2.5 cm).
I ordered the SPAX adjustable shocks and with the PU-Buschings and a 5mm shortened tube at the front roll-bar we will se. I will try the 20mm spacers and shorter front spring-blade from the 6.3, as you told me there could be some problems with the clearance of the steering-box , we will see... As you know a took the brake-moment system from the airsuspenzion and the swaybar at the rear for better the brake effeciency and to get relaxed braking in front of the turns. If that is not enough I will go for the progressive ones. You've 3.5 springs or 220 for the car?
Best Pagodino
pagodino is offline
post #6 of 6 (permalink) Old 02-18-2010, 05:21 PM
BenzWorld Elitist
Marsden's Avatar
Quoted: 453 Post(s)
Wow thanks. Fascinating material!
Marsden is offline
    Progressive Springs? bklynbenz1 W210 E-Class 2 05-24-2009 01:37 PM
    W123 Progressive rate & sport springs Veloce300DT W123 E,CE,D,CD,TD,TE Class 2 10-20-2006 06:50 PM
    sport shocks + stock springs = ? zebinheimer300e W124 E,CE,D,TD Class 2 08-06-2006 01:10 PM
    Progressive vs Linear Springs petermerle G-Class 6 03-29-2006 07:15 AM
    I got my AMG Springs today...they don't look like they're progressive springs, Brian? Any comments? Arnee - Sacramento, R170 SLK-Class 7 02-22-2001 08:29 PM
