Help About W115 Fuel Consumption - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 02-11-2010, 05:13 AM Thread Starter
Azkoul's Avatar
Date registered: Jan 2010
Vehicle: '76 W116 280SE '75 w115 230.4
hi all
i have 1976 W116 280SE and i just got W115 230.4 my W116 is taking about 11-13 L\100KM Driving at 90-140 Km\h
the Problem is my W115 is Burning about 13-16 L\100 Km hardly get 140km\H
i Don't think this normal at all Cause W116 is 6Cylin 2800CC and W115 is just 4Cyli 2300
So How is this ?? and what the Normal Fuel Consumption for the W115
Help guys
Azkoul is offline
post #2 of 5 (permalink) Old 02-11-2010, 07:53 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
Your 116 is fuel injected, your 115 is carburated. Probably your carb needs adjustment. But these cars are gas hogs.
Scoot is offline
post #3 of 5 (permalink) Old 02-12-2010, 06:01 AM Thread Starter
Azkoul's Avatar
Post
Thnx Scoot
But the carburetor is suck i must buy another one and the Engine need Cleaning
it's not a matter of Fuel injection and carburetor
but i still wanna know the Normal Fuel Consumption of w115 i think it's not this thirsty
i will consider buying a M110 i think it fits without any problem
Azkoul is offline
post #4 of 5 (permalink) Old 02-13-2010, 06:30 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
One thing to keep in mind is the M115 is trying to push a heavy car. 100 horsepower to a 1400 KG car. How fast can you run with an extra 14 KG strapped to your back?
My M115 (originally in a 1972 220 and now in a 1972 250C) with twin down-draft Solex carburetors would only get 15 mpg on a good day (sorry, I don't feel up to doing the metric conversion) and top out at about 80 MPH. So, that is actually lower than your 140 kmh. Of course, speedometers vary and an error of 10% is not all that uncommon. It usually averaged about 13 mpg on "in-town" driving and about 17 mpg high-way driving.
The use of proper shift points will help your mileage. Run a vacuum line through the firewall, attach a vacuum gauge and try to keep the needle reading as much vacuum as possible. You'll quickly get a feel for when to shift and the optimum engine speed for the best mileage. It's quite common for people to "over-rev" the little 4 cylinders to attempt to get the acceleration they think the car should have.
The M110 will fit and give you more power. The trade off is if you get the Solex 4A1 you will have even more carb problems. If you drop in a M110 I'd suggest getting an injected engine. Not exactly a "drop-in" installation but it is do-able. The M110 will drop the horsepower to weight ratio to about 9 to 1 as compared to the 14-1 ratio you now have, even lower with the injected engine.
There are alternatives to the 4A1 carburetors.
2 BBL carb with adapter plate
or
4 BBL Quadrajet carb (Solex'es are an European licensed copy of the Rochester Q'jet).
Mike D is offline
post #5 of 5 (permalink) Old 02-15-2010, 02:37 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Original brochure says the 200/8 consume 10.9 litre/100km (combined)
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
    How is better for fuel consumption: isarescu R170 SLK-Class 3 02-01-2008 01:21 AM
    fuel pump affecting fuel consumption? rich369 W140 S-Class 0 11-22-2006 08:32 PM
    Fuel issue in 75 250D w115 Dr Evil Vintage Mercedes-Benz 1 10-22-2006 07:08 AM
    Fuel consumption Guest (MBNZ) W203 C-Class 8 08-06-2001 06:05 PM
