WIPERS WON"T GO OFF!!! NEED HELP!!! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 02-08-2010, 06:13 PM Thread Starter
74benzo's Avatar
Date registered: Sep 2009
Vehicle: '74 280
I have a '74 280, and my wipers will not turn off. Can someone please help me? They will occasionally stop when the car is stopped or something. I really don't know whats wrong!
74benzo is offline
post #2 of 3 (permalink) Old 03-22-2010, 11:54 PM
Date registered: Mar 2010
Vehicle: 1975 240d w115.117
Send a message via AIM to allenb83
You may have a faulty or loose wire in your turn signal assembly. You can unplug the relay from the wiper motor to disable it for the time being if you don't want to ruin your wiper blades. This relay should be a little black 5 prong connection, connected to the round barrell under your hood, near the right drivers side corner, or the relay could be attached to a wire coming out of it. The motor should be connected to the firewall. (firewall= the panel that separates the engine compartment under the hood from the inside drivers seat area). Check your turn signal switch by taking it apart and looking for loose connections or corroded connections/ wires. Hope this helps!
allenb83 is offline
post #3 of 3 (permalink) Old 03-23-2010, 11:48 AM
Date registered: Feb 2010
another possibility, could be a bad relay (doubt it though) but you can check that by switching two of the relays...if your wipers are good and something else goes hay-wire, then its the relay
Former MB: "Miss Juliana" - 1972 280SEL 4.5
Current MB: 2013 C250
HBguy is offline
    S500 Wipers won;t stop on OFF Position. HELP!!!! benzoboy W220 S-Class 8 04-25-2011 04:38 PM
    1996 E320 Hi-Beams won"t work mlk2724 W210 E-Class 2 02-11-2009 06:47 PM
    Australian Import 280SE Won"t Start Aussie116 W116 S, SE, SEL, SD Class 0 08-17-2008 05:14 AM
    Anyone put on "SINGLE BLADE" Wipers, from W209 CLK ? danger450 R170 SLK-Class 0 03-28-2008 02:56 AM
    right "stick" for controlling wipers liquid died? quepao W163 M-Class 0 02-17-2007 01:35 AM
