Help with gas milege and current noise - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-08-2010, 01:06 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1988 560 SEL LH drive/1973 450SL
My 1973 450SL 4.5l motor, Just got it in Hawaiiand have put two tanks of gas thru it Primeum and the milege is less than 10 miles to the gallon. Is this normal any suggestions to increase this would be appreciated. Also getting alot of exhaust fumes in the compartment. I am waiting for the replacement muffler since the one I have is leaking out of every seam and the whole front is patched up and the pipe are leaking at the muffler. Hopefully this replacement will help it out. Any suggestion with this would be helpfull also.
Next problem on the way to work the speedometer started to sign real loud to me. I can feel the vibration when touching the from of it. I presume it is the speedometer its self and not just the cable since the needel stays steady and it not bouncing all around but not sure. Do not see any indication of air bags but my manuals have not arrived and I now use this for work so was wondering if anyone could lead me to an easy way to pull this instrument cluster out. looks like have to pull the steering wheel to get to it and hopefully I can just oil it up and take care of the problem and at the same time put some graphite in the cable.
my manual has not arrived yet so any help would be great.
Thanks in advance, someday hope to be able to be able to provide some helpfull information to the group and not always be asking questions. Aloha
Menehune is offline
post #2 of 2 (permalink) Old 02-08-2010, 01:13 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Aloha nui loa,
Let's start with the simple stuff. When was the last tuneup? If you're not sure, just swap everything out.
The cluster removal doesn't require for the steering wheel to come off but it is a lot easier with the wheel off. Do a search in the 107 section for the procedure, a number of people have done it.
flyboyike is offline
    Most milege on a e320? Any threads? 94dawgfan W124 E,CE,D,TD Class 9 02-07-2008 01:06 PM
    Current Gas Prices.... Kiawah W140 S-Class 61 05-25-2007 10:53 AM
    Milege of w211 brake discs sturtles W211 E-Class 12 11-01-2005 08:02 AM
    Current 350/55 owners. Current status? amcmahon R171 SLK-Class 32 01-15-2005 07:28 AM
    ML-55 real fuel milege Mo Eckley W163 M-Class 8 04-09-2001 11:53 AM
