1972 280se 4.5 - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 02-05-2010, 04:42 AM Thread Starter
Date registered: Nov 2009
Vehicle: 280 SE 4.5
1972 280se 4.5
Hey guys! Well I'm back, and this time I have money again to put into my ride. So I already installed a new silinoid on the starter, and a fuel pump. It cranks over and that part of it sounds strong and healthy, but its like its missing something. My question is this, what part in this particular model is in charge of powering the electrical system (which is supposed to send fuel thru the lines, im not getting fuel past the motor, but its pumping up to it) I am buying an owners manual today, but just thought I would get a headstart. I appreciate any feed back! Thanks again! Could it be a certain fuse block? OR?
Billy Benz
Mr.Benz1 is offline
post #2 of 9 (permalink) Old 02-05-2010, 05:14 AM
Vehicle: 1972 280se 4.5 Silver/Maroon
Could be ECU fuse issue, trigger points in distributor, check wiring harness below dist. cap. Injectors bad. Have you pulled the injector rail and verified no fuel? Check this for detailed troubleshootiong
D Jetronic
marcedesbenz is offline
post #3 of 9 (permalink) Old 02-05-2010, 12:05 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 107 Post(s)
Start with the ignition sytem. Verify you have spark to the plugs. The most important parts of running the car are the ECU, the fuel pump and associated relays. All the other sensors can be unplugged, and the engine will still run (but poorly). I'd doubt that the trigger points are bad - those rarely fail.
Take a look at the online resources portion of the forum - lots of stuff has been posted there on your car.
Cheers!
Grubeguy is offline
post #4 of 9 (permalink) Old 02-15-2010, 12:40 PM Thread Starter
Vehicle: 280 SE 4.5
Thanks guys, your advice is greatly appreciated.
Mr.Benz1 is offline
post #5 of 9 (permalink) Old 02-16-2010, 12:42 PM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
That particular model has a power supply wire at the battery positive post attached to the main positive cable end. That wire is the primary power feed for the fuel injection system. from there there are two relays attached to the panel behind the computer in the engine compartment. One runs the FI system and maybe the other runs the fuel pump, not altogether sure as to the fuel pump relay. check the power supply wire at the battery first.
Bill
Bill A is offline
post #6 of 9 (permalink) Old 02-23-2010, 01:32 PM Thread Starter
Vehicle: 280 SE 4.5
Bill- thanks for your advice! Ironically enough, my roommate and I have done just that, but I didnt know about the primary battery wire either. So, I opend up both the relays and they looked burnt up? I believe that is our issue, but I am going to check the battery supply first, thanks again Bill!
Mr.Benz1 is offline
post #7 of 9 (permalink) Old 02-25-2010, 06:40 PM
Fuel pump relay is underneath the ecu. You can hear it come on for 2 seconds when you turn the key. Replace burnt relays with nice new clean working relays. Then car will start.
Maybe
On ECU
The ground of the ECU is terminal 11 verify that with battery ground, chassis.
Check voltage at 24 and 16 with key on. These are your main relay power to ecu connections. Should be 12 volts. Injectors are powered by ECU, if your not getting voltage at these terminals, you got bad main relay or who knows what.
You got these links right
D Jetronic
http://members.rennlist.com/pbanders/djetfund.htm
post #8 of 9 (permalink) Old 03-22-2010, 12:12 PM Thread Starter
Vehicle: 280 SE 4.5
Hey thanks again!! You've been a great help, sorry I just saw this post (you can ignore the other) Hav a good day, and thanks for helping this young, unexperienced Benz owner advice haha
Mr.Benz1 is offline
post #9 of 9 (permalink) Old 03-22-2010, 12:17 PM Thread Starter
Vehicle: 280 SE 4.5
I'm looking to buy the relays that are just left of the battery, and it was my understanding that they look identical to the fuel pump relays, but are multi purpose relays. Ironically, I remember seeing them on a website at PelicanParts.com, and then when I get the money, I couldnt find them. When I start the car, my roomate and I could hear the relays click, but not all of them..
Mr.Benz1 is offline
New Member: 1972 280SE betoface326 General Mercedes-Benz 3 08-08-2009 02:52 PM
1972 280se 4.5 sixseries Vintage Mercedes-Benz 2 01-31-2009 09:09 PM
1972 MB 280SE Feeler ARRUDACRUISER1 For Sale/Wanted/Trade/Giveaway 0 01-18-2009 12:37 PM
1972 280SE 4.5L car and 1972 280SEL 4.5L parts car for sale benzmeister_WI For Sale/Wanted/Trade/Giveaway 6 09-10-2007 04:38 AM
1972 280SE 4.5 Guest (MBNZ) General Mercedes-Benz 0 04-13-2001 09:06 PM
