converting from points to electric iginition help - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 02-03-2010, 12:12 AM Thread Starter
hugedodge2000's Avatar
Date registered: Jan 2010
I have a 67 250s with the straight 6 in it. I am tired of messing with the points system in it. Where is the best place, or company, website, to get the electronic module where the points go and how much do they cost? I have the 2 piece points system so it has the pivot pin to slide the points on and the points point to the left in the distributor. Thanks guys!!
hugedodge2000 is offline
post #2 of 16 (permalink) Old 02-03-2010, 03:59 AM
cadurning's Avatar
Date registered: Dec 2009
Vehicle: '72 280SE barn find
hudgedodge2000,
You are doing a good thing. Don't listen to those nay sayers talking about rejecting flawless Mercedes engirneering and keeping your MB concours correct. Points had their time but now it's time to step into the 20th century.
I have used Pertronix in all of my old cars and boats. Pertronix is compact and reliable. I'm sure that some one will chime in with a story where their Pertronix system shot craps, I've never had that experience. George Murphy is one source for Pertronix.
perfanalysis@comcast.net
Ignitor
Another option is Hot Spark. I've never used one of those but the price is right. I undersrand that Hot Spark is a clone of Pertronix but at less than 1/2 the price.
Electronic Ignition Conversion Mercedes 200 220 230 280 : eBay Motors (item 310193275755 end time Feb-07-10 10:31:37 PST)
There is the Crane system but I haven't found any information in that one.
Lastly there is the 123 Ignition. 123 looks slick but is expensive. I may consider the 123 system when I get rich & famous.
123ignition electronic ignition systems for classic cars
My '72 280 is getting the Pertronix next week.
If it's not broke it dosen't have enough features.
cadurning is offline
post #3 of 16 (permalink) Old 02-03-2010, 07:47 AM
CRJ9Driver's Avatar
Date registered: Nov 2009
Vehicle: 1956 Buick Century Coupe, 1937 Pontiac Business Coupe
I am doing the same thing... once I get to it. This is what you need. Ebay, new, $56. Cheers!
PerTronix (Hall Effect) Ignition for Mercedes-Benz Pontons © www.mbzponton.org
CRJ9Driver is offline
post #4 of 16 (permalink) Old 02-03-2010, 08:26 AM
cadurning's Avatar
CRJ9Driver,
Thanks for the link
post #5 of 16 (permalink) Old 02-03-2010, 08:59 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
I have Pertronix also and it works great. One warning - do not leave the ignition in the on position with the car not running for hours. It will fry the thing.
Scoot is offline
post #6 of 16 (permalink) Old 02-03-2010, 01:28 PM
Necrosavant's Avatar
Date registered: Aug 2007
Vehicle: 1962 220S(200d engine),1970 Cadillac Fleetwood 75,1984 500SL
same thing applies for the points mine would burn up if i left it on for more than 5 mins though..ill probably go same route to electric ignition..my points will only last like 2 weeks before i see the timing make jump all over the place..thought about getting the 123 ignition (there video is amazing) but thats a lot of money to swing right now
111 1962 220s (200d engine)
1995 S350
1983 300TD
Necrosavant is offline
post #7 of 16 (permalink) Old 02-04-2010, 06:01 AM
Vehicle: 1972 280se 4.5 Silver/Maroon
Got my pertronix from Summit racing here in Ga. THey had it in stock. Also got the flamethrower coil for v8. Works flawless, easy to install. I ran an extra ground wire straight to the battery to be on the safe side.
marcedesbenz is offline
post #8 of 16 (permalink) Old 04-03-2010, 09:09 PM
DerFuror's Avatar
Date registered: Apr 2009
Vehicle: 1993 MB 500E, 1965 MB 220b
I upgraded my 1965 220b's ignition with a Crane Fireball XR700 2 seasons ago (basically for similar maintenance reasons as others have posted). I was quite happy with the results. The only thing we vintage drivers must remember is that we are adding-on new technology components to an exisiting mechanical distributor "host" that can be 30 to 50 years old. A real result of what can happen follows:
To end last year's driving season, I went for an extended drive culminating under high speed conditions. Everything performed fine. I was very pleased with this aspect of the EI unit. I then put the car into storage for the winter. I brought the car out of storage 2 weeks ago. This is a car that I've had for nearly 30 years. It has been mechanically very well maintained. I squirted a little gas into the dual Solex carbs (as I usually do if the car has sat for a prolonged time) & the car started right up & ran smoothly. Choke was barely necessary at all. I was very pleased with this aspect of the EI unit.
I then adjusted the tire pressure, made sure all lights worked, added some fresh gasoline & went for a ride on a gorgeous St.Patrick's Day. The drive included in-town & highway. Before I got too far out of town, the ignition back-fired several times, then died as I was halfway up a highway off-ramp. It was running spectacularly up to that point. I turned the key, it started promptly, ran for 5 seconds, then died again. Upon inspection, I saw something that I don't recall ever seeing before...the cast iron distributor housing had actually fractured a bit more than half its circumference from one grounding screw hole to a cap clamp screw hole!! You could easily slide a playing card within its gap. This fracture caused a disruption which broke a section of the "tooth" holding the rotor in its fixed position on the distibutor shaft. The back firing occured once the rotor moved out of its proper position. I flatbedded the car home.
So, to make a long story shorter, I purchased a new 123Ignition for the best price I could find (prices vary significantly!). I too saw their video comparison, read all the info I could find on this item & searched far and wide regarding prices. I am in the process of installing this unit. I'll provide an update on the results. I chose this item because all of the EI technology is housed in a single brand new mechanical unit. It is a direct replacement unit. I knew my original Bosch distributor (even though serviced properly) was my ignition's weak link simply because of its 45 years of mechanical wear. I am really looking forward to driving this car knowing its replacement distributor is brand new & technologically optimized.
This mechanical failure experience formed my decision in purchasing the 123Ignition.
1. I wasn't going to replace an old distibutor with another old distibutor (even though I have the spare parts I need).
2. I wasn't going to purchase a new replacement Bosch distributor, only to upgrade it with my Crane EI components.
3. I wasn't going to let the car languish by doing nothing just as the driving season is getting ready to start & I wasn't going to sell the car just because the distributor crapped out!
You probably bought your MB because you like it & want to enjoy driving it around for as long as you can. The decision to upgrade to EI is sound. The decision regarding the extent of the EI upgrade really comes down to a pay now or pay later situation. Based on your car's condition & your monetary situation, which extent of the EI decision will allow you to pay less in the long run??
I will most likely put the Crane EI system up for sale. It is complete with all original components necessary for 4,6 or 8 cylinder car ignitions, documentation & box. I was very pleased with its performance but no longer have an immediate use for it.
PS - check your distributor housing for fractures running between its various screw holes.
DerFuror is offline
post #9 of 16 (permalink) Old 04-05-2010, 12:22 AM
Vehicle: Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
If you seen there are several systems on the market, all are reliable and functioning well. I used all of them in the last 10 years. I think what you will use depends on what you have. If you distributor is good (no joke, thight bearings) and you are able to registrate the vacuum unit un it using the stroposkope the petronix, ignitor, luminition are good for you (lower cost). If you distributer shows any wear so use the 123-ignition.
If you will go a step on you can decide to make a Megasquirt conversion with modern ignition and efi. If your car is carburator it is possible to, using injectors like that one used on older Chryslers ('80). Singelpoint injectors will fit in the carbs. Triggerwheel in the diestributor wich an optical sensor and a large band lambda. You will end up with a new old car. If you have a mechanical-injection, HK-ingeneering made a regulator (stepper-motor) instead of the centrifugal injection regulation. A sort of mechatronic injection system with lambda controll, repruduceable with Megasquirt.
Best Pagodino
pagodino is offline
post #10 of 16 (permalink) Old 04-05-2010, 09:43 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Yep - go Pertronix. I've got one in my 108 and it made a world of difference.
Grubeguy is offline
    Converting the 5 Litre Engine to an 3 Litre Engine + A Electric Motor? Zonet W140 S-Class 60 10-19-2009 04:09 AM
    Stuck iginition wires 01SL500 W126 S,SE,SEC,SEL,SD,SDL Class 3 03-09-2009 11:38 PM
    Iginition on 'N' gear only?! helenso General Mercedes-Benz 1 06-03-2008 08:34 AM
    Converting SLS mechanical pump to electric NovaScotia300TD W123 E,CE,D,CD,TD,TE Class 1 09-05-2007 08:31 AM
    Converting Door locks to Electric sporkins W123 E,CE,D,CD,TD,TE Class 7 06-22-2007 06:12 AM
