immediate help - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-25-2010, 09:30 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1974 240d
immediate help
I was trying to start my 1974 240d and it turned over for half a second than it just stoped. I checked to see if the battery was the problem, but it seems alright. Its almost midnight here so i have to wait until later tomorrow. Im thinking it could be the starter, but hoping its something else. If you have any suggestions message me back.
pollracker is offline
post #2 of 7 (permalink) Old 01-25-2010, 10:49 PM
Joshua Lomax's Avatar
Date registered: Jul 2009
Vehicle: 1972 250 saloon
can you hear the starter clicking or is it just one click? or no click at all?
1972 250 S
Joshua Lomax is offline
post #3 of 7 (permalink) Old 01-26-2010, 12:26 AM Thread Starter
Vehicle: 1974 240d
no click at all
post #4 of 7 (permalink) Old 01-26-2010, 07:18 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Define "the battery seems alright".
flyboyike is offline
post #5 of 7 (permalink) Old 01-26-2010, 10:13 AM
Vehicle: 1964 Mercedes 220Sb
My guess would be CORROSION, can't tell you how many people say "it's a new battery," I pull out a pocket knife scrape the insides of the terminals and it starts right up.
If the cables, terminals, battery are all good then check the starter solenoid, dunno if it's on the starter or firewall in that model... internet says its on the starter:
https://mercedessource.com/node/6444
An easy check for that is jump the two thick bolts with a thick screwdriver you don't care about too much (the arcs will pit it), if it sparks and the starter still don't turn over you got a bad starter. If it does turn over, you got a bad solenoid or ignition.
to test the solenoid jump the thick bolt on the solenoid thats connected to the battery to the tiny bolt (where the ignition connects). If it turns over you've got a bad ignition.
I started my truck with a screwdriver for a week before I bothered replacing this at one time...
tgikal is offline
post #6 of 7 (permalink) Old 01-26-2010, 12:10 PM
diametricalbenz's Avatar
Date registered: Oct 2005
Vehicle: '77 6.9, 74 240D, 96 Ram 5.9L Cummins, 02 Civic EX, 10 Mazda 5 Sport
Quoted: 4 Post(s)
I used a metal file in a pinch too although the arcing ruins the teeth.
1977 - W116 - 6.9
1974 - W115 - 240D /8 - 4(M) OM617.910 + Turbo + 300D FW - Completed 7/8/10
diametricalbenz is offline
post #7 of 7 (permalink) Old 01-26-2010, 05:31 PM Thread Starter
Vehicle: 1974 240d
well the battery was fine I tinkered with the starter, pulled the fuses on the relay and tightened it all up. Its running just fine now thank you all for the help. Like i said it was almost midnight when i couldn't start it so i got to it today.
