Not getting the power I should...HELP!!! - Mercedes-Benz Forum
post #1 of 17 (permalink) Old 01-17-2010, 11:34 PM Thread Starter
hugedodge2000's Avatar
Date registered: Jan 2010
Since I got my 67 250s it hasnt had power to pull the hills. They arent terribly steep but I know it should go faster than it does floored in 2nd gear. It has the 2.5 in it. IT does fine in the flats, just doesn't accelerate the best. Second gear floored on a hill and it feels like the car almost comes to a stop. What could my problems be???? It's not the power steering or air condishoner dragging it down because I pulled the belts from those to check that already. Could a bad waterpump cause that much of a power loss. I have noticed a little wobble in my waterpump pulley I think its from bad wp bearings so I have a new one of those on the way. THANKS!!!
hugedodge2000 is offline
post #2 of 17 (permalink) Old 01-18-2010, 08:58 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I doubt the waterpump would bog the engine down that much - I'd check the transmission first. Hows the flat acceleration? Or top speed?
Grubeguy is offline
post #3 of 17 (permalink) Old 01-18-2010, 10:38 AM Thread Starter
top speed takes a while to reach, no way it could happen in the hills though, acceleration is ok on the flats, dnt know what to compare it to because ive never driven another one. What could the tranny do to bog it? It shifts and drives smooth....
post #4 of 17 (permalink) Old 01-18-2010, 01:08 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Transmission is your most likely culprit.
However, you said you have never driven another 250, so you don't have much to compare. If you are comparing it to the acceleration of a modern car, even a modestly powered one, it may be that the acceleration you are experiencing is normal. The 250 is not a powerful car; in fact, to say acceleration is "adequate" is probably being charitable. It is the classic case of a lot of car and not much engine.
That said, it should pull hills okay and not lose speed in lower gears.
If the transmission is okay, a compression check is the next thing I would try. If your engine is losing compression because or worn rings, it will also be losing power.
How many miles on the motor?
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #5 of 17 (permalink) Old 01-18-2010, 06:35 PM Thread Starter
It has 105k original miles. What could be wrong with the tranny?
post #6 of 17 (permalink) Old 01-18-2010, 07:00 PM
It could be broke.
Have you checked the fluid level? That's always a place to start.
Even if the fluid level is okay, the next thing I would do is change the fluid and filter. It's maintenance that should happen along about 50-60k miles, but you have a 42 year-old car. The transmission may never have had routine maintenance, may have had routine maintenance 30 years ago, may have had routine maintenance 10 years ago. All of those are WAY too much time to leave fluid in the case and rely on it to do its work. In the process of changing the fluid, a good shop will adjust the bands and do other non-repair work to make the tranny work better.
If none of that helps, see the first sentence.
Good luck.
DrJfrmLA is offline
post #7 of 17 (permalink) Old 01-18-2010, 07:01 PM
Oh, if you would take time to fill out your profile, knowing where you are might help you find someone nearby who is a good mechanic or who has a car like yours and can help.
DrJfrmLA is offline
post #8 of 17 (permalink) Old 01-18-2010, 07:21 PM Thread Starter
really? The tranny fluid can cause it to bogg that much? That's crazy, but i'll check it out!! thanks guys!!
post #9 of 17 (permalink) Old 01-18-2010, 07:24 PM
It's not bogging, it's slipping.
DrJfrmLA is offline
post #10 of 17 (permalink) Old 01-18-2010, 07:34 PM Thread Starter
If it was slipping the motor would rev up. the motor slows down right along with it. Never had any weird noises from the tranny and it shifts fine. It bogs going up hill. I know it takes a lot of power to pull 4300 lbs up a hill but it should go up smooth in 2nd gear.....my tranny is a 4 speed on the column by the way so I dont think it has any filters to change.
    passenger side power seat bottom power not working. tonydale@gmail.com R129 SL-Class 12 07-26-2012 06:59 PM
    87 560SEC driver side power seat (no power) alabbasi W126 S,SE,SEC,SEL,SD,SDL Class 8 07-12-2010 08:34 AM
    losing power from the power seats jdmgc W203 C-Class 6 08-31-2009 06:48 AM
    Power Seats, then Power Windows... Metafly W202 C-Class 15 06-11-2009 04:46 PM
    Can i refit power fold side mirrors and power tailgate kevinchung W164 M-Class 6 06-15-2007 01:19 AM
