what is it all about - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 01-17-2010, 12:28 PM Thread Starter
Date registered: Oct 2009
Vehicle: w111 3.5 coupe
i heard and read a few people comment that a few w111 3.5 cars burned down coz of the gas/petrol lines?
i just got my car and off course do not want anything bad to happen to it
so what is it all about? and how can i try to stop my car burning down?
i might be wrong and just mixed up things
thanks guys
ds58 is offline
post #2 of 5 (permalink) Old 01-17-2010, 01:31 PM
thebenzbar's Avatar
Date registered: Feb 2005
Those V8's have a 28-30 psi high-pressure EFI system... check for your fuel lines' wear, age, dry-rotting, leaks, and secured fit/connections.
If there is anything abnormal & leaks while the engine is running & hot... then be ready with a fire extinguisher, just in case.
thebenzbar is offline
post #3 of 5 (permalink) Old 01-18-2010, 03:18 AM Thread Starter
thanks benzbar you are the w111 resident expert
ds58 is offline
post #4 of 5 (permalink) Old 01-18-2010, 05:46 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Yes, the D-Jetronic system uses hose top injectors and also quite a few hoses in the fuel cicuit on top of the engine. These hoses should be inspected and retightened regularly and replaced before they start leaking due to age. Yours may have already been replaced given the overall good condition of your car but you should at least inspect them (As you had your injetors checked ask the guys if they replaced the hoses or if they were in good shape). If they have been replaced recently or if you replace them do not forget to retighten them regularly at the beginning (no need to squish them completely though).
I always have a multipurpose blanket in my trunk that I can also use to choke a fire. If you ever feel something is on fire under the hood cut the contact immediately as this will stop the pump from sending fuel at high pressure on the fire. Also beware that if and when you open the hood this will bring additional air to the fire and you may end up with big flames. This is where a blanket is handy but you must have it ready before opening the hood. An extinguisher is of course the safest device but it damages your engine bay quite as much as the fire itself. That foam is extremely corrosive.
GGR is offline
post #5 of 5 (permalink) Old 01-18-2010, 07:10 AM
Necrosavant's Avatar
Date registered: Aug 2007
Vehicle: 1962 220S(200d engine),1970 Cadillac Fleetwood 75,1984 500SL
left my shop the friday with the 62 w111, stopped at fuel station to refuel, while filling i went to check the oil and i had a pretty bad leak from my mechanical fuel pump, i ran up to discount got some washers retightened lines with new washers and was back on the road
111 1962 220s (200d engine)
1995 S350
1983 300TD
Necrosavant is offline
