what is this on the floorboard? - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 01-14-2010, 10:04 PM Thread Starter
hugedodge2000's Avatar
Date registered: Jan 2010
What is the black billow thing on the floor to the left of the clutch on the floor. It has a metal ring around it and has a vaccum hose going into it. What is it and whats its purpose? Thanks!!
hugedodge2000 is offline
post #2 of 12 (permalink) Old 01-15-2010, 02:53 AM
thebenzbar's Avatar
Date registered: Feb 2005
Foot pump for the windshield washer system.
thebenzbar is offline
post #3 of 12 (permalink) Old 01-15-2010, 06:39 AM
cadurning's Avatar
Date registered: Dec 2009
Vehicle: '72 280SE barn find
Yep that's what it is. Push on it with your foot and the wipers should move.
If it's not broke it dosen't have enough features.
cadurning is offline
post #4 of 12 (permalink) Old 01-15-2010, 09:50 AM Thread Starter
Thanks guys!!
post #5 of 12 (permalink) Old 03-18-2010, 03:34 PM
Date registered: Feb 2010
Just a heads-up, EU and some US models have a switch there...mines electric (1972 280SEL)
HBguy is offline
post #6 of 12 (permalink) Old 03-22-2010, 11:31 PM
Date registered: Mar 2010
Vehicle: 1975 240d w115.117
Send a message via AIM to allenb83
A switch for what exactly? Mine has a hollow tube going into it so it must be for the windshield wipers... so they work manually when you press on it? Or is it for the fluid to squirt on the windshield? I wondered what that could be myself when I was replacing my windshield wiper motor.
allenb83 is offline
post #7 of 12 (permalink) Old 03-23-2010, 09:44 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 88 Post(s)
I don't have information specific to your model, but I believe earlier versions had both a momentarily on electric swith controlled by the metal ring that activated the wipers and a rubber ball in the center of the ring that when depressed would pump fluid through the washer nozzles.
ejboyd5 is offline
post #8 of 12 (permalink) Old 03-23-2010, 12:43 PM
One sent voltage to the washer fluid pump and the other to the wiper motor...I believe. I know both are activated with the switch and the switch is a double pole double throw.
My wiper arms don't work though (just bought the car) and all fuses are good. I'm not too anxious to get to the wiper motor, especially when I couldn't find the bolt that holds the cluster (to remove it first).
Former MB: "Miss Juliana" - 1972 280SEL 4.5
Current MB: 2013 C250
HBguy is offline
post #9 of 12 (permalink) Old 03-23-2010, 01:46 PM
Date registered: Nov 2009
Vehicle: 1972 280se 4.5 Silver/Maroon
Not sure why there would be a switch for an electric pump on the floor, I understand mine being on the floor because you have to manually pump it with your foot. But for electric, if stock you would think it would be on the normal wiper switch. Wonder if its been retrode along the way.
marcedesbenz is offline
post #10 of 12 (permalink) Old 03-23-2010, 02:17 PM
The foot pump style is US only apparently, and only on some vehicles.
Much more info is available about this on the peach parts forum.
HBguy is offline
    pass well floorboard clip oreif W163 M-Class 2 04-16-2009 08:55 AM
    Water in floorboard Dimmuburger W124 E,CE,D,TD Class 16 01-10-2009 05:20 PM
    wet floorboard ace00959 W123 E,CE,D,CD,TD,TE Class 6 09-19-2006 09:05 PM
    Floorboard cracking? rubiconjp G-Class 1 12-08-2004 07:50 PM
    floorboard repair/replacment ericdab G-Class 3 08-07-2003 05:31 PM
