Some questions about LIQUI MOLY 0W-40 synthetic motor oil and 500SL compatibility - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 01-12-2010, 01:40 PM Thread Starter
Date registered: Jun 2009
Vehicle: 1990 500SL
When my 500SL comes out of storage in April, I want the best oil I can get. I bought the car with 24,000 original KM in December of 2008. It has never been winter driven, and never used at all between 1994 and 2009. I currently have 32,000KM, so I am not sure if I should go synthetic. I figure since the car is an antique by modern car standards, it couldn't hurt to go synthetic early into its actual use (the motor is barely broken in, in real terms). I was advised that Liqui Moly makes the best oil for German cars like mine because consumption is less than, say, Agip. Since my 1990 Benz is designed for 10W-30, will there be a problem in compatibility for a modern oil with little to no drag whatsoever (0W-40)? Is my vintage car built for these tolerances, or would a zero W oil cause the motor to run too freely for its own good?
Rolexmonger is offline
post #2 of 2 (permalink) Old 01-13-2010, 01:26 AM
Emre-K's Avatar
Vehicle: '87 190E 2.3-16
Seems like you're really asking 2 different questions.
First, there's the question of Liqui Moly oils in general. I'm not sure you can find them by that name in North America. We get "Lubro Moly Voll-Synthese" here, which is made by Liqui Moly and is presumably the same stuff they sell in Germany. Voll-Synthese is generally considered top-shelf stuff. It's specifically approved for long-life use in BMWs, Porsches, M-Bs, and VWs.
I believe (though I'm not 100% certain) they use a genuine, full-synthetic formula based on PAO or ester stocks. If that's the case, then I'm not sure Voll-Synthese is really any better than any other motor oil using Group IV or V base stocks, such as Red Line, Amsoil, Elf, or Motul.
Your second question is regarding which grade you should use. It's generally a bad idea to run a thinner grade of oil than that recommended by the manufacturer. If M-B recommends 10W-30, then I certainly would not run 0W-40.
1987 W201 190E 2.3-16: Vintage racer
1990 C124 300CE coupe: Daily Driver
1991 Peugeot 405 Mi 16: Weekend Toy
Emre-K is offline
    Liqui-Moly MOS2 jerk_chicken General Mercedes-Benz 0 09-01-2009 03:55 AM
    liqui moly? chopstick1 R170 SLK-Class 12 02-10-2009 08:31 AM
    Diesel treatments other than Liqui Moly? BG? benztech123 W123 E,CE,D,CD,TD,TE Class 0 05-15-2007 05:53 PM
    Liqui Moly Diesel Purge.......DONE! hotwheelbill W123 E,CE,D,CD,TD,TE Class 13 11-04-2006 04:50 PM
    Synthetic motor oil hashem72 W124 E,CE,D,TD Class 2 03-26-2003 09:48 AM
