75 240D injection pump oil consumption - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 02-06-2010, 07:15 AM Thread Starter
Date registered: Aug 2003
problem solved
I am thankful for the help and advice that I recieved from the Forum and I'll share what the problem was.
The lift pump.
It was good to go through the minor component diagnosis (filters, tank screen, hoses, pressure valve spring) to make sure that the simple things were correct first. Turns out that the lift pump was siezed and the IP was the only thing that was sucking fuel. No wonder it was starving.
Switched out the lift pump with a part from Mercecessource and it's been golden ever since.
Now on to the other various minor issues, but at least the car is reliable for my son to drive locally.
Thanks again.
-Henry Jackson
hjackson is offline
    Testing injection pump on 240D frenchfry W123 E,CE,D,CD,TD,TE Class 16 11-18-2009 03:14 PM
    240d oil consumption dyonsl W123 E,CE,D,CD,TD,TE Class 2 09-18-2008 07:03 AM
    W123 Injection Pump Oil jhancoc W123 E,CE,D,CD,TD,TE Class 4 04-24-2007 10:12 PM
    What is normal oil consumption for 240d? jsl@gorge.net W123 E,CE,D,CD,TD,TE Class 3 06-13-2006 01:32 PM
    240D Injection Pump wdba123190 W123 E,CE,D,CD,TD,TE Class 1 08-21-2003 04:13 PM
