Starting W111 Fintail Engine up after 10 years - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 12-30-2009, 04:17 PM Thread Starter
Date registered: Feb 2007
Vehicle: 300 SL 24V 1990, 1995 E220 Saloon (w124), 1995 W140 S500 Coupe , 1978 280 cew (w123)
I have today (upon impulse) purchased a W111 1963 Fintail. Its been in a barn for 10 years.
When it arrives the first thing I want to try to tackle myself is to get the car fired up. Ive never had a car so old and stood for so long so what do i need to do before cranking the old girl? Ive read that i need to try to manually turn the engine over (if possible???) - if so how?
I guess i should drain all the oil/ coolants and perhaps petrol and replace with new clean ones - is this correct? Common sense would say this is sensible!
If i would need to lube any pistons how would i do this? take the rocker cover off and pour oil down the rocker????
as much advice would be appreciated for this pen pushing novice as i dont want to hurt my fintail before i even begin restoring her - pics will be posted when she arrives next week.
at the moment im try to read and understand as much as possible to understand what ive just blindly bought !
Happy new year to all too!
ifzal_uk is offline
post #2 of 10 (permalink) Old 12-30-2009, 04:36 PM
CH4S Artist
Teutone's Avatar
Date registered: Sep 2004
Vehicle: 1985 500SEC, 1991 190E 2.6.
Quoted: 1014 Post(s)
I am not the expert here, but I think you squirt a little oil through the spark plug holes.
I heard of Marvel mystery oil being added and allowed to do whatever it does, before cranking.
Try a few benzworld, or forum searches. If not sure how, the 'Welcome to the Forum' tutorial / announcement on top of the W126 page will show you.
I remember my father's W111 220SE well.
Cheers
Teutone is offline
post #3 of 10 (permalink) Old 12-30-2009, 04:57 PM Thread Starter
cheers pal - any advice is appreciated.
What if the engine is a diesel? I shouldve mentioned this in my post.
ifzal_uk is offline
post #4 of 10 (permalink) Old 12-30-2009, 05:32 PM
Welcome to the old car start-up world.
So many things to do before starting.
First pull plugs and apply ATF (skip the Marvel Oil) into the cylinders.
Rotate crankshaft manually through the full cycle of firing order.
Is it carburetors or fuel injection?
Sniff the gas tank for old fuel,
If you gag and puke, the entire fuel system MUST be corrected.
Write to us after this is complete.
Check for decently clean oil in the crankcase.
Water is a separate issue, you do not need water to start and run, just need it to run more than a few minutes.
Brian O
bostosh is offline
post #5 of 10 (permalink) Old 12-31-2009, 01:20 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
@ botosh
It's a diesel.
Govert70227 is offline
post #6 of 10 (permalink) Old 12-31-2009, 08:56 AM Thread Starter
Thanks for the advice - as its a diesel would you change the glow plug? if so where is the glow plug located on the fintail diesel engine? a picture would be good.
ifzal_uk is offline
post #7 of 10 (permalink) Old 12-31-2009, 10:26 AM
Necrosavant's Avatar
Date registered: Aug 2007
Vehicle: 1962 220S(200d engine),1970 Cadillac Fleetwood 75,1984 500SL
if its a diesel, it would be a custom transplant, for the w111 finny didnt come as a diesel only the w110 finntail
111 1962 220s (200d engine)
1995 S350
1983 300TD
Necrosavant is offline
post #8 of 10 (permalink) Old 12-31-2009, 10:28 AM
Date registered: Jul 2009
Vehicle: 1964 Mercedes 220Sb
Was looking for some info on valve adjustments and the only thing I found in this forum happen to be on a diesel... Maybe the site he listed will help:
Originally Posted by mybenz123 View Post
These two links should help.
Mercedes Diesel Valve Adjustment Procedure
Althought none of these say it but it is a good thing to
remove your glowplugs before you start this.
Reason being is that if you remove them the chance
of any compression build up is voided.
I will make turning the engine a lot easier.
Louis.
tgikal is offline
post #9 of 10 (permalink) Old 01-08-2010, 04:29 AM
230Terry's Avatar
Date registered: Jan 2004
Vehicle: 93 320 CE, '55, 220a, '72, 280SE 3.5, '88 Mini Mayfair, '90 Peugeot 205GTI, .04 Mini Cooper
Quoted: 28 Post(s)
Not an expert on diesels but there should be four plugs on the right side of the motor.
Turned over my ponton after sitting for five years.
Took the plugs out then some light oil into the cylinders and left it sitting overnight.
Put a socket wrench on the end of the crank (in the centre of the fan) and turned it over by hand as described above with the plugs out to reduce compression.
When I was happy it was running free I turned it over on the starter and it turned over nicely.
Winter closed in so I have not got it started as I need to clean out the fuel tank and replace the fuel lines.
But at least I knoe it turns over and there is a sprk at the plug.
Good luck.
230Terry is offline
post #10 of 10 (permalink) Old 01-16-2010, 05:20 PM Thread Starter
Good luck.
cheers ...silly question but as i have no keys yet how do iistart the car from the starter ?
ifzal_uk is offline
    W111 220S Fintail (Sunroof model) $3000obo johnnyIXI For Sale/Wanted/Trade/Giveaway 3 04-24-2010 08:02 PM
    Please HELP on W111 Engine Timing vilamoura General Mercedes-Benz 0 09-27-2009 05:13 AM
    1971 MB 280SE 3.5 “Fintail” Cabriolet (W111) Question viejopatron Vintage Mercedes-Benz 1 09-27-2008 12:10 PM
    Anyone parting W111 Fintail? or source for parts? johnnyIXI Vintage Mercedes-Benz 5 06-27-2007 12:06 AM
    W111 Fintail interchanges? FinnyFiend Vintage Mercedes-Benz 1 02-02-2004 03:13 PM
