72' 250C Starter Question - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 12-30-2009, 08:42 AM Thread Starter
pdub's Avatar
Date registered: Jun 2008
Vehicle: 1972 250C
72' 250C Starter Removal Help Needed
Hi there.
I was hoping someone where might help me. I think the starter went out on my 72' 250C yesterday.
When I try to start the car I just get a ticking / flapping type sound. Battery is good etc.
Before replacing the starter I wonder if there is anything else it could be? Relay etc?
Any help would be greatly appreciated.
Thanks in advance.
Charles.
pdub is offline
post #2 of 9 (permalink) Old 12-30-2009, 09:31 AM
Remove starter, disassemble, clean, if brushes are worn replace,
They respond like new with a cleaning.
The brush material gets all over the area and causes elect. leakage.
I've done a few like this with good cheap results.
Well built starters.
Brian O
bostosh is offline
post #3 of 9 (permalink) Old 01-05-2010, 09:42 AM Thread Starter
pdub's Avatar
Vehicle: 1972 250C
Thanks for your reply. That's some real DIY! I purchased a rebuilt starter already. I am having problems figuring out how to get the starter out though. The bottom bolt seems simple enough when accessed from below but for the life of me I can't figure out how to get the top bolt off.
Thanks, Charles.
pdub is offline
post #4 of 9 (permalink) Old 01-05-2010, 01:10 PM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
An extension with a universal.
renaissance_warrior is offline
post #5 of 9 (permalink) Old 01-05-2010, 03:04 PM
Date registered: Mar 2009
Vehicle: 1967 W110 230, 1972 250c
Same potential problem with my 72 250C
I have a similar problem with my 250C. What do you mean by universal?
Like the previous post mentioned; the one bolt looks doable, but not
the other one.
Bla8310
Chicago
Bla8310 is offline
post #6 of 9 (permalink) Old 01-05-2010, 11:44 PM Thread Starter
pdub's Avatar
Vehicle: 1972 250C
An extension and universal it is!
Thanks I will give it a try this weekend.
Charles.
pdub is offline
post #7 of 9 (permalink) Old 01-06-2010, 09:26 PM
wbain's Avatar
Date registered: Dec 2003
There should be a small metal cover on the right side of the trans hump under the carpet. If there is, remove the screws and the starter bolt is there.
wbain is offline
post #8 of 9 (permalink) Old 01-08-2010, 10:20 AM Thread Starter
pdub's Avatar
Vehicle: 1972 250C
I checked on the trans hump and did not find any access panel. That would have been nice. Thanks for the tip though.
Charles.
pdub is offline
post #9 of 9 (permalink) Old 01-17-2010, 02:19 PM Thread Starter
pdub's Avatar
Vehicle: 1972 250C
It was indeed a job for the extensions and universal! It's a 10mm Allen. It's not an easy job at all. Thanks so much for all the help.
Charles.
pdub is offline
    '72 250C Points Gap and Timing Question pdub Vintage Mercedes-Benz 0 04-10-2009 03:53 PM
    '71 250c engine question No game Vintage Mercedes-Benz 3 01-13-2009 01:03 PM
    starter wiring 250c? badboy430 Vintage Mercedes-Benz 0 05-09-2007 04:16 PM
    1972 250C fender removal question robinmcdowall Vintage Mercedes-Benz 1 02-02-2007 09:57 AM
    72' 280 se- becker europa question? george tukey Vintage Mercedes-Benz 4 12-30-2004 03:37 PM
