I'm considering buying a 1973 280 - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 12-29-2009, 01:29 PM Thread Starter
Date registered: Dec 2009
Hi all, I'm considering buying a 1973 280 auto with 90K miles on it but only minimal maintenance done on the car. I have yet to look at the vehicle as it will demand traveling to another city. What are things I should look out for? I know the original carbs are an issue (and costly to replace-how much??), and the heater core is a nightmare to work on. Any other problems common to this model? Suspension issues, tranny?
Also the leather on the seats are saggy... and it has two small dents in the rear fenders. Cost for vehicle is $2200.
eortiz is offline
post #2 of 11 (permalink) Old 12-29-2009, 03:25 PM
Date registered: Nov 2009
Vehicle: 1972 280se 4.5 Silver/Maroon
Mines a 280 se 4.5 if thats what your looking at then should be fuel injected dJetronic. I got mine for less than half that and it is pretty sweet. Had to do a few repairs, but drove it out of the place. Replaced hoses, belts, water pump, alternator, battery and pertronix ignition install. Look for rust inside the front wheel wells and trunk. Would think that price might be a bit high. Post some pics if you can and more details.
marcedesbenz is offline
post #3 of 11 (permalink) Old 12-29-2009, 04:19 PM Thread Starter
Here are pics, still waiting on the engine info...
eortiz is offline
post #4 of 11 (permalink) Old 12-29-2009, 05:05 PM
Looks pretty nice there. Mines a 4 door so thats what I was going by. Someone else will need to chime in because I know the coupes are a lot more desirable and are worth more.
post #5 of 11 (permalink) Old 12-29-2009, 05:38 PM
thebenzbar's Avatar
Date registered: Feb 2005
Some factory info/specs for that W114 280... ignore the bottom right pic on the 1st page, that's a w108.
ID:	281745   Click image for larger version
thebenzbar is offline
post #6 of 11 (permalink) Old 12-30-2009, 03:02 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
The Solex carbs can be a bear to work on. I had a 114 and replaced the carb with a generic one (I think it was a holly, but don't quote me on that). The kit came with the adapter plate and everything else I needed.
That stated, once the solex is rebuilt, adjusted and set correctly, the car will run like a top. How much a rebuild kit is, or what it might cost to have done professionally ... is beyond my knoelwdge.
Seats are easy to re-stuff. The pads are rubberized horse hair pads. I replaced mine in hours, once I got the seats out of the car.
Grubeguy is offline
post #7 of 11 (permalink) Old 12-30-2009, 03:07 PM
patrick800's Avatar
Date registered: Aug 2006
Vehicle: 1973 MB 280C (sold), 1976 MB 300D, 2009 VW CC 4motion
I had the same car in red. Beautiful car but the solex carb gave me problems (stalling, rough idle, hard to start). Replacing it with a weber carb was not a good idea.
patrick800 is offline
post #8 of 11 (permalink) Old 12-30-2009, 11:07 PM
Grubeguy's Avatar
Quoted: 103 Post(s)
Aha!! Thanks for jogging my memory - mine was a Weber too. It was just a generic carb with jets installed to make the car run. Mileage didn't get any better, but it ran better than with the solex carb. In retrospect, I should have just rebuilt the thing and called it a day.
Grubeguy is offline
post #9 of 11 (permalink) Old 01-01-2010, 01:53 AM Thread Starter
Thanks for the info. Grubeguy...when you say that replacing the seat pads took hours-how many?
eortiz is offline
post #10 of 11 (permalink) Old 01-01-2010, 09:14 AM
ollo's Avatar
Date registered: May 2009
Vehicle: S430 93K; E420 243K; 240D 242K
Quoted: 65 Post(s)
The 73 280 I had back in the 80's came with a 4 barrel carburetor which had problems, but a rebuild cured it. Since it has been neglected, do a valve adjustment & transmission service right away. You should plan on replacing the timing chain & guides before putting to many more miles on it.
ollo is offline
    1973 280 SE 4.5 lpalos@roadrunner.com Vintage Mercedes-Benz 1 12-05-2008 04:03 PM
    New to Merc's - Looking at buying a 1973 280 - help please ! :) Ryan27 Vintage Mercedes-Benz 5 07-03-2007 08:51 PM
    1973 280 kardar Vintage Mercedes-Benz 5 11-06-2006 07:24 AM
    1973 280 Se 4.5 gtwillis Vintage Mercedes-Benz 7 09-02-2006 03:43 AM
    Advice on buying 1973 280 4-door Gazolba Vintage Mercedes-Benz 3 09-01-2006 08:55 PM
