Fuel system flooding - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 12-26-2009, 12:27 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1972 350 SL
Question Fuel system flooding
I purchased a 72 350sl with a 4,5l V8 about a month ago. It had been sitting for about 2 years so I drained the gas tank, flushed the lines with new gas and drain again, then installed a new fuel filter, added new gas with treatment. I started the engine, it ran good for about 30 seconds then started running rough and putting out black smoke. I shut it off and could not get it started again until I remove the spark plugs and dried out the cylinders and plugs, which were soaked with gas. What would be the things I need to check and or replace? I cant afford to spend much because money is very tight.
robbin is offline
    Fuel System Service Procedure - Fuel Distro, Lines and Injectors BenzHacker R/C107 SL/SLC Class 10 03-29-2010 04:36 AM
    Fuel Additives - Sonax Fuel System Cleaner MaxR129 R129 SL-Class 21 07-12-2009 03:17 PM
    Fuel Additives - Fuel Injection System Cleaner SHOOTER15 R129 SL-Class 24 07-05-2009 07:57 PM
    FS: Bench Fuel Injector Tester and Fuel Injection System Pressure Tester JRBrown For Sale/Wanted/Trade/Giveaway 1 02-20-2006 08:50 AM
    Fuel vapor recovery system (fuel lost) rramsa01 R170 SLK-Class 2 06-15-2004 12:50 AM
