W111-109-108-113 Mods - Page 14 - Mercedes-Benz Forum
post #131 of 162 (permalink) Old 05-04-2014, 06:12 AM Thread Starter
Date registered: Apr 2009
Vehicle: Mercedes 280 SE 3.5 coupe, pagoda 230 SL '64, 500 E W124, CE 220 Cabrio, E 320 T W211, w126 6.0 AMG
Some more picks
If someone want to see some more picks of my restomod 3.5 Coupe and 500E manual conversion, join me on facebook Patrick Welte.
Best Pagodino
pagodino is offline
post #132 of 162 (permalink) Old 04-09-2015, 05:25 AM
Date registered: Dec 2008
Vehicle: 1965 W111 Coupe (with a twist).
Quoted: 4 Post(s)
Hi Pagodino, and others interested in modded classic Mercedes.
I have long been interested in owning a W111/2 coupe, and the possibility of using it as a daily driver.
Recently I purchased a modified 220SE Coupe. It has been fitted with a Chevy 350 motor and 400 transmission. It has disks all round. It looks very nice and drives quite well.
I would be interested in any comments on the car - its mods, any others I should consider. Also the pros and cons of daily driver use.
I live in Connecticut, and am interested in meeting other coupe owners, also looking for parts suppliers - new and used and also a source for manuals.
I look forward to hearing your thoughts!
ID:	1393001   Click image for larger version
ID:	1393009   Click image for larger version
ID:	1393017   Click image for larger version
ID:	1393025   Click image for larger version
ID:	1393041   Click image for larger version
ID:	1393049   Click image for larger version
JohnMott is offline
post #133 of 162 (permalink) Old 04-09-2015, 05:57 AM
Date registered: Jun 2004
Quoted: 5 Post(s)
Red face
That looks like a nice car. i'm no fan of the push rod chev and I know 1st hand how much effort is required to install one into a Mercedes chassis ( note the highly modified sump) .You will only need a chassis and body manual for that car, which are available from the Mercedes Classic center in Irvine , California. Engine and trans info is available anywhere in the USA. i wonder what diff ratio it has?. most mercedes rear ensds are far too low for Chevs unless you want to blast from traffic light to traffic light.
Have fun,it looks like a great driver! .
oefvetw124lover likes this.
mercmad6.3 is offline
post #134 of 162 (permalink) Old 04-09-2015, 06:08 AM
oefvetw124lover's Avatar
Vehicle: toys: 92 400e,92 300CE & 93 400SEL with daily driver:12 Civic, Workhorse: 15 F150 & Porsche 944
Quoted: 1047 Post(s)
Send a message via AIM to oefvetw124lover Send a message via Yahoo to oefvetw124lover
350 i an awesome motor !
that car rocks !
is it a crate 350 ?
do you have the build sheet ?
I had a 78 Camaro with a 350, I had plans to do a crate motor.
tell us more about the car
Albany, NY, USA
92 300ce and others
"Men sleep peacefully in their beds at night
because rough men stand ready
to do violence on their behalf."
Si vis pacem, para bellum
oefvetw124lover is offline
post #135 of 162 (permalink) Old 04-09-2015, 03:56 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
The diff does not have an oil tube which means it is a 6cyl diff. I would install a 3.27 from a 280se 4.5 to drop your RPM. Very clean conversion and nice car-not the usually hack job.
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #136 of 162 (permalink) Old 04-09-2015, 04:15 PM
Quoted: 4 Post(s)
Thank you for the replies.
I do not have a build sheet. I have not ID'd the motor yet, but I don't think it's a crate motor.
As to the diff, I suspect it is from a 250SE.
The car does around 70+ MPH at 2500 rpm - which seems OK, what do you think? I will check the tach is reading correctly!
Appreciate any and all advice.
JohnMott is offline
post #137 of 162 (permalink) Old 04-09-2015, 05:04 PM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon/'01 EV Weekender
Quoted: 1419 Post(s)
Looks like a fairly clean drivetrain swap. Might be cool to install a polished M117 air cleaner assembly, with the added bonus of being able to run a snorkel up front for a cold air intake.
Zeitgeist is offline
post #138 of 162 (permalink) Old 04-22-2015, 06:19 PM
Quoted: 4 Post(s)
Thanks for your posts.
I have been going over the car and it does indeed have a crate motor - a 2002 GM 350 (330HP), a GM TH700R4 transmission (4 speed overdrive), a later 3.27 disk brake differential, thermostatic electric fan, working AC, and runs on 6.5" x 14 bundts.
So whoever put this together back in the early 2000's knew what they were doing. All the class of a W111 coupe with some Go!
So far I am very happy with the car, tho the idea of fuel injection is tempting...
JohnMott is offline
post #139 of 162 (permalink) Old 04-23-2015, 07:23 AM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
i would use a v6 engine .
agillot is offline
post #140 of 162 (permalink) Old 04-23-2015, 03:11 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
WTF? Another random gem from agillot. I think you mistook this thread for twitter.
John, the car looks great and I bet it sounds nice too! There are always articles in Hot Rod and Street Rodder magazine about FI conversions on carb motors. You can go the easy route with a bolt on system that looks like a carb but is FI and basically self-tunes (just need an O2 sensor I think), to a full on FI system with fuel rails and nozzles etc (megasquirt, BigStuff 3, Atomic etc). The last issue of Hot Rod I got (maybe 2 months ago) had an article in the back where a guy had a chev truck that he had a shop convert to EFI. It barely ran, and 3 shops had no luck in getting it to work. So the magazine helped him get it fixed up. A guru in the US managed to guide them over the phone to sort it out. It was interesting to read about how the original shop had screwed it up so badly, but now that it was fixed, the guy loved it.
My recollections from reading the various articles was that the bolt on systems (like FAST) are a slight improvement over carbs (easier cold starting, better throttle response) but economy and power were not much different. The full systems gave better everything, but obviously cost more and are more complex to set up - need to know car weight, engine, cam, dif ratio, tyre diameter, and what you want (power, economy etc). They really need a dyno to fine-tune everything.
Hop on one of the web sites such as this (Electronic Fuel Injection - Street Rodder Magazine) and search for fuel injection.
drew56cus is offline
  • Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
    108/109 Rear Fenders Grubeguy Vintage Mercedes-Benz 2 11-20-2009 09:49 PM
    108 vs. 109 neemhakim Vintage Mercedes-Benz 4 08-13-2007 07:49 AM
    Engine swap for a 108/109 chassis 56kabrio Vintage Mercedes-Benz 5 12-30-2006 01:56 PM
    108-109 vapor barrier fatshot Vintage Mercedes-Benz 5 07-18-2006 11:09 AM
    Available Parts for W120,108,109,110,111,112,113 Linea Vintage Mercedes-Benz 1 10-20-2004 09:50 PM
