Let's try this again ;) 1972 Mercedes-Benz 280SE - Page 2 - Mercedes-Benz Forum
post #11 of 25 (permalink) Old 12-24-2009, 09:38 PM Thread Starter
Date registered: Nov 2009
Vehicle: 280 SE 4.5
From what I was told, the vehicle was sitting for that of around 5 years... I hope everyone has a wonderful and warm Christmas!
Mr.Benz1 is offline
post #12 of 25 (permalink) Old 12-27-2009, 03:06 PM
Date registered: Dec 2009
Vehicle: 1972 350 SL
I'm going through the same problem with my 72 350sl with a 4.5 . It would roll over and hit every once in a while but not start. I pulled all the plugs, disconnected power to the fuel pump, turned the motor over for about 15 seconds to dry the cylinders,and put it back together It started right up, but immediately started to flood out. After I shut it down it went back to not starting again. So you may have the same problem I do. If I can figure it out I'll let you know.
robbin is offline
post #13 of 25 (permalink) Old 12-28-2009, 10:02 AM Thread Starter
Vehicle: 280 SE 4.5
Ok man thanks a lot for the post, I'll try doing as you did to see if it sparks up.. thanks again! Kansas weather right now in kc is awful, im glad i put that thing in the garage!
Mr.Benz1 is offline
post #14 of 25 (permalink) Old 12-28-2009, 10:36 AM
No problem. I know what you mean about the weather its not much better in NW Arkansas. I just received a string about checking the points. You can check out all the info I got in the roadster forum section for 1971-1989 SL cars on down the forum. After wrote the top part of this the temp warmed up into the mid 30's so I decided to check the vacuum lines and I found the line from the MAP to the back of the engine was broke. So for a test check I taped the hose together and cranked up the engine, it run a lot better now, only a little rich but not rough any more. Before I do any more I'm going to replace that line.
robbin is offline
post #15 of 25 (permalink) Old 12-28-2009, 03:56 PM
Date registered: Mar 2008
Billy, nice to see how much you've learned, and bettered your approach from your original "style".....your original posts.
Nice to see the support you're now receiving with your new approach.
Clearly you've learned much......sincerely bravo to you.
Best wishes to you, your son & success with your car,
David
David
1970 250
1970 280 SL
1994 C 220
1991 350 SDL
1995 E320 Cabriolet
DReisbord is offline
post #16 of 25 (permalink) Old 12-30-2009, 11:23 AM Thread Starter
Vehicle: 280 SE 4.5
Ok.. I'm kind of confused on which route I should take.. because I dont yet hav enough money to purchase a new fuel pump relay, but its possible it may not be that, correct? Robbin, any suggestions on what I should do exactly first? Sorry, and again, thank you for your advice, it is very helpful.
And David, thanks a bunch, hav a safe, and fun New Year!
Mr.Benz1 is offline
post #17 of 25 (permalink) Old 12-30-2009, 11:23 AM Thread Starter
Vehicle: 280 SE 4.5
I'll read thru your other forum as well.. see ya!
Mr.Benz1 is offline
post #18 of 25 (permalink) Old 12-30-2009, 01:44 PM
The first thing I would do is make sure you are getting gas to the engine, by removing a fuel line at the engine. If you do have gas getting to the engine I would then change the vacuum line from the MAP unit to the engine. I would also check the fuel pressure at the pressure regulator. I'm learning all this by reading what I can find on this site and books. I'm new at Benz I usually work on Suzuki and Ford. Try to google 1972 Mercedes 4.5 engine repair, then go to the title 280 SE 4.5 engine trouble, read over all three pages. That is how I found this site.
robbin is offline
post #19 of 25 (permalink) Old 01-03-2010, 10:26 AM Thread Starter
Vehicle: 280 SE 4.5
Hey man thanks! Ok so I'm really excited to get this thing goin, and now my roommate is telling me that their is no power going to the fuel injectors that go to the motor. I guess thats it!
Thanks everyone for your inputs, and advice!
Mr.Benz1 is offline
post #20 of 25 (permalink) Old 01-03-2010, 10:28 AM Thread Starter
Vehicle: 280 SE 4.5
So... I am about to load it on the ramps and follow the wiring to find out whichever fuse block it is, that powers the fuel system.
Mr.Benz1 is offline
    1972 Mercedes-Benz 280SE Mr.Benz1 For Sale/Wanted/Trade/Giveaway 213 07-06-2014 04:04 PM
    1972 Mercedes-Benz 250 Sedan miatasportscar Vintage Mercedes-Benz 2 02-18-2009 07:56 PM
    1972 Mercedes Benz 280 SE kavadarci Vintage Mercedes-Benz 5 08-28-2008 10:20 AM
    1972 Mercedes Benz 300SEL 4.5 Parting out alabbasi For Sale/Wanted/Trade/Giveaway 0 01-12-2008 05:57 PM
    1972 Mercedes-Benz Convertable? HITWTOM Vintage Mercedes-Benz 8 08-06-2007 01:28 PM
