The four(4) dashboard signs of my 300D MB - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 12-30-2009, 09:40 PM
Date registered: Dec 2007
Vehicle: 1967 250SE, 2004 E500, 2005 C320, 2006 SL500
Quoted: 4 Post(s)
light bulbs check
When you turn the ignition on, the car performs a short light bulb check and all indicators light up for 1 or 2 seconds. If one of them stays lit then you have a problem. As mentioned before it would be the parking brake applied or low brake fluid level. Regular brake fluid should be ok for '77 brake system but you may want to check the parking brake. If the cable is loose and you have the parking brake as a small pedal to the left the weight of the pedal may pull it down and close the switch for the brake warning light. I had this particular problem so you may want to rattle the pedal and see if the light turns on. This may hold true if you have the parking brake as a hand lever too (sorry I don't remeber which models have the pedal or the lever).
gafitanu is offline
post #12 of 12 (permalink) Old 12-31-2009, 12:26 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
The right-hand drive versions have a lever, left-hand drive have a pedal.
Govert70227 is offline
    '84 300D Dashboard Warning Light Question BuckeyeTheDog W126 S,SE,SEC,SEL,SD,SDL Class 4 04-08-2009 03:19 AM
    Signs, Signs, Everywhere the Signs. Politics 08 mcbear Off-Topic 4 10-01-2008 07:44 PM
    dashboard lights don't work-300D stormydeska W123 E,CE,D,CD,TD,TE Class 11 09-21-2007 05:35 PM
    Black Dashboard + Console For Sale 1984 300d panamacolin For Sale/Wanted/Trade/Giveaway 3 01-10-2007 09:15 AM
    300D dashboard is not working lemmyb W123 E,CE,D,CD,TD,TE Class 3 08-26-2004 11:14 PM
