Plug Erosion from Electronic Ignition? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-28-2009, 04:35 AM Thread Starter
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Roughly a year ago, I drove my '73 280se 4.5 from San Diego to Denver (about an 1100 mile trip). Prior to, I had changed the plugs, wires, etc. My dad's got the car currently, and has put another 100 miles or so on it. It began to misfire so when he checked the plugs, he found that they were badly eroded and also fouled.
I've got a Pertronix unit with a high energy coil in the car, and am wondering if anyone has had a similar experience. He read somewhere that the gap should be 20 thousandths (not that I remember the normal, rated gap for the original setup), and when he adjusted it as such, the car ran like a champ.
Any thoughts on the matter?
Grubeguy is offline
post #2 of 2 (permalink) Old 12-05-2009, 05:46 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
I'm not familiar with the Pertronix set-up. I guess I should say, I don't use the Pertronix but I do use the Crane optical set-up with a high performance coil and I have never noticed any problems.
What type of "erosion" are you talking about? A white, glazing or melting of the porcelain? That is usually the sign of either a lean "burn" or a too advanced spark ignition. Could be a vacuum leak or you have the mixture set too lean.
Melting of the electrode or center contact? Definitely an "over voltage" condition.
Try changing to a "colder" plug if everything else checks out.
Plug gap's original specs are .028"or maybe it was .023". I run my NGK BP6ES's at .032" to actually promote a hotter spark, 'course that is on my M110's and M115.
The original "close" gap was because the stock Benz ignition is weak and the voltage was reduced through the trigger switch points to enhance longevity hence the "transistorized" spark booster box.
Mike D is offline
    Electronic Ignition Key mishael W202 C-Class 4 12-15-2007 11:51 AM
    Electronic ignition - any advantage? Gazolba Vintage Mercedes-Benz 4 10-11-2006 09:04 PM
    Electronic Ignition for your classic MB! Norb Vintage Mercedes-Benz 1 01-05-2006 01:25 AM
    Total Electronic(ignition) Failure. Dascat Audio & Telematics Forum 3 08-17-2004 05:26 AM
    Total Electronic(ignition) Failure. Dascat W202 C-Class 0 06-01-2004 04:00 PM
