Clutch release bearing/pressure plate compatibility - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-22-2009, 06:28 AM Thread Starter
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 11 Post(s)
Hi all,
I recently purchased a V8 3.5 pressure plate on EBay. The picture advertising it was this one:
I also got a release bearing from another supplier p/n 0002506815 pictured below:
The pressure plate I received was not the same as the one pictured, as it has that additional contact surface with the release bearing compared with the advertised one:
I believe that type of pressure plate is an earlier model and may also have to work together with an earlier type of release bearing, as the one pictured below:
According to EPC, both the pressure plate (3rd picture) and release bearing (second picture) I received are correct part numbers for the 3.5, but as there are several p/n for each item, I wonder if that 'later type" release bearing would work with the "earlier type" pressure plate, or if I should ask the supplier to switch the pressure plate he sent me with the one he advertised.
GGR is offline
    Manual Transmission Clutch Release (Throwout) Bearing? little_r_a W123 E,CE,D,CD,TD,TE Class 3 08-06-2009 04:21 PM
    Where to get clutch disc and pressure plate for my 3.5? GGR Vintage Mercedes-Benz 0 06-22-2009 07:41 AM
    Clutch resurafacing, pressure plate masterdog R170 SLK-Class 6 06-29-2008 09:20 AM
    4-Speed Clutch Release Bearing little_r_a W123 E,CE,D,CD,TD,TE Class 0 11-02-2005 06:45 AM
    Clutch and pressure plate Toronto230GE G-Class 3 06-06-2005 09:00 AM
