Engine overhaul - 240D - What's the cost of overhaul? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-21-2009, 04:12 PM Thread Starter
Date registered: Nov 2009
1977 240D with 200k miles. Lot's of blow-by. The car runs OK. I was thinking of rebuilding the engine myself. I'm guessing one or more of the cylinders is bad. Any wild guess as to the cost of rebuilding the 240D engine?
hd89044 is offline
post #2 of 3 (permalink) Old 11-21-2009, 08:36 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Here is a bunch of part prices, if that helps: Mercedes OM616 Engine Parts
GeeS is offline
post #3 of 3 (permalink) Old 11-22-2009, 01:13 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
First do a compression test and a leak test. Than you know how much life there is in your engine and if there is a specific problem with one or more of the cylinders.
Govert70227 is offline
    83' 240D manual 716.210 transmission overhaul Ajaxman W123 E,CE,D,CD,TD,TE Class 1 09-10-2009 04:54 PM
    Engine Overhaul idkmybffcms W124 E,CE,D,TD Class 9 04-16-2009 10:48 PM
    engine overhaul CaptainHook C208/A208 CLK-Class 7 05-13-2008 12:03 PM
    300 SE Major Overhaul parts and cost - need advise mibaspeedo W126 S,SE,SEC,SEL,SD,SDL Class 4 02-14-2006 11:34 PM
    300TD rear suspension overhaul cost Niloc W123 E,CE,D,CD,TD,TE Class 10 01-16-2006 01:47 PM
