1973 450 sel Gas tank removal - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-19-2009, 07:13 AM Thread Starter
Date registered: Nov 2009
my Father in law had a 73 450 sel in garage for about 20 years. His wife had parked the car because my wife and her brother didnt know how to drive at 16 and scrapped the side. So they parked it in the garage. The car was operational before putting the car into storage. After 3 years of begging he has finally given it to me SWEET. Put gas in the carb to see if it would fire up after filling the oil and radiator fluid and new battery. Surprisingly it did. From what I have been reading to bring this girl back from the dead I need to clean the gas tank out. I have a place that will clean it but I need some pics or info on how to remove it. I have already replaced the fuel pump and the filter that I obtained through bap. Any help or advise would be appreciated.
Thank you in advance
Romedog
New proud mercedez owner.
1973 mercedes 450 SEL (GAS)
romedog is offline
post #2 of 2 (permalink) Old 11-19-2009, 11:14 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Right on! Nice car! Gas tank removal is actually pretty easy. First, remove the connection to the sending unit (from the inside of the trunk). While under the car, you'll see something like 6 bolts holding brackets that in turn hold the gas tank in place. Loosen/remove all that, and the tank comes right off.
Grubeguy is offline
    1973 450 SEL nemw01 W116 S, SE, SEL, SD Class 1 05-05-2009 04:00 AM
    Pressure release from gas tank,450 sl rsanders R/C107 SL/SLC Class 3 04-28-2009 07:13 PM
    gas tank removal CivicTuning2 W126 S,SE,SEC,SEL,SD,SDL Class 1 01-12-2006 09:23 AM
    using Acetone in my 420 SEL gas tank............... Benzerman General Mercedes-Benz 1 04-12-2005 01:26 PM
    1973 450 SEL Fuel Economy hradek Vintage Mercedes-Benz 2 06-28-2004 02:11 AM
