59' 190D prime issue - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 11-16-2009, 08:49 PM Thread Starter
Date registered: May 2009
Vehicle: 62' Unimog, stretched and caged.
Hello, I recently pulled the original diesel engine to put it in a kid sized offroad buggy project. (SBC 350 to go into the 190D body) The little diesel ran good prior to pulling it last week. Today after re-plumbing everything up and replacing all old crusty fuel lines, I attempted to prime the system. I pumped that dang pump at least 200 times. I could only see a small amount of fuel rise up into the clear filter. Once I stopped the fuel would drop right back into the tank. Also, should there be any resistance in pumping because there was NONE. Super easy the whole time. Yes I opened the valve on top of the filter.
Another question I have is would a new inline 12V fuel pump (self priming)work in the system instead of the old style hand pump, and if so, would I need to remove the original pump?
Thanks for any help
1993 Jeep Wrangler with 404 axles
1962 Mercedes Unimog 404
MogDogg is offline
    1984 2.2L 190D Cruise Control Issue freddyx W201 190-Class 2 11-25-2008 10:57 PM
    190d "85" auto shift issue gymi Vintage Mercedes-Benz 0 10-05-2007 05:28 AM
    300sd IP won't prime? proudhon W123 E,CE,D,CD,TD,TE Class 2 07-01-2006 04:36 PM
    Past her prime Botnst Off-Topic 4 04-17-2006 02:17 PM
    some prime cuts djugurba Off-Topic 2 10-28-2004 02:46 PM
