74' 280 Timing
810 views 2 replies 2 participants last post by  74benzo
Can anybody tell me what the timing should be on my car? Its the inline six with a single carb. If someone can tell me it would be awesome! Thanks.
With vacuum lines disconnected and plugged, engine at idle, in neutral, at operating temperature, 10 degrees BTDC.
At apx. 3000 rpms the manual advance should advance the timing to apx. 30 degrees BTDC.
With vacuum lines attached, at an idle, the timing should drop to about 4 degrees ATDC. This is for emissions purposes. If the vacuum solenoids are working correctly (which they never are after 35 years) the vacuum retard mechanism is disabled after 1500 rpms.
