Looking at a 1978 240D 4spd with 210K on it... - Mercedes-Benz Forum
post #1 of 25 (permalink) Old 11-15-2009, 04:22 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1979 300CD (no eng/tran) 4spd OM616 (possible swap), 1984 300D "Murky"
The guy selling it says it runs good but the battery will dischage very fast like there is a short somewhere? it seems to be in good shape for the year...
I'm kinda wondering how much it would be worth if I can fix the draining batt problem and what kinda problems I should look for b4 buying it?
(I'd like to make it a resto/driver project) are they decently peppy for getting around town with the 4spd manual?
Thanks a lot!
-NW
Twenty1+1 is offline
post #2 of 25 (permalink) Old 11-17-2009, 01:08 PM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
Peppy? Maybe in 1st gear. This model is built for long distance runs but will deliver around town too. Many were used as cabs in Europe. Rust and worn rear axels will be two problems to look for, rust being a major contributor to electrical gremlins. Motor mounts, tierod ends, steering damper, shocks, radiator clogging with rust, check all of these.
Ed Mclass is offline
post #3 of 25 (permalink) Old 11-18-2009, 09:02 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Are you sure there's an electrical problem, or just a weak battery? Or an almost-out alternator? Batteries and alternators can be checked at the local parts store - they most often test them for free.
As for pep, the non-turbo diesels were never known for being sporty. Good on fuel consumption though...
Grubeguy is offline
post #4 of 25 (permalink) Old 11-18-2009, 12:47 PM Thread Starter
hey guys thaks for the info!!! But alas I didnt end up getting it... I think I'll stick with my auto 300D Turbo...
post #5 of 25 (permalink) Old 11-24-2009, 03:56 PM Thread Starter
Well, the guy just got back to me and said he didnt end up selling it, So I may end up getting it... I'll post later with info...
post #6 of 25 (permalink) Old 11-24-2009, 11:38 PM Thread Starter
Talking I bought it!
It was 2 whole quarts low on oil!!! but it had been sitting for 3 years... (1000 miles in 3 years qualifies as "sitting" in my book) and the clutch is in desperate need of a replacement... but for how it looks and how the engine runs (added 2 1/2 quarts b4 we started it) I couldnt pass it up
Is there a how to on here about replacing a 240D clutch?
post #7 of 25 (permalink) Old 11-24-2009, 11:41 PM Thread Starter
It was the alternator! (has a brand new battery) Jump started it and by the time I got home I could barely see the road the lights were so dim!
post #8 of 25 (permalink) Old 11-25-2009, 08:44 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 115 Post(s)
Pep up your 240 D
You can "pep up" your 240 D with a nice set of aluminum (11 pounds each) wheels. That removes about 80 pounds of unsprung weight (so the car will be great in the obstacle course!) and another 20 pounds in the trunk. If your car is a 1978 chances are that it has 30+ pounds steel wheels... they take the same wheel cover and were sold on MBs for a couple of years (after 1978, before Bundt). Let me know if you want more info or pictures...
Scoot is offline
post #9 of 25 (permalink) Old 11-25-2009, 09:41 AM
Grubeguy's Avatar
Quoted: 99 Post(s)
Well, I'm not a sage on diesel clutches, but experience with other cars taught me that clutch replacement is more or less straight forward. Remove the starter, clutch cables or linkage, and start removing bolts from the engine. Be sure to support the transmission after you remove tranny mounts and drive shaft. The whole thing will then come down. Last time I did a clutch, it took me 7 hours to take down and about as much to bolt back in....
Grubeguy is offline
post #10 of 25 (permalink) Old 11-25-2009, 10:23 AM Thread Starter
I would definitly go for some lighter wheels! (would the ones on my 1985 300D Turbo be the aluminum ones? (the dont have the hub caps tho?)
    240D 4spd manual consumption dyonsl W123 E,CE,D,CD,TD,TE Class 9 09-20-2008 06:08 PM
    '82 240d 4spd - Now for sale! wv240d W123 E,CE,D,CD,TD,TE Class 3 07-18-2006 12:33 PM
    what is more desirable a 81 240d 4spd stick or 78 300d 4spd stick? eso7 W123 E,CE,D,CD,TD,TE Class 5 02-06-2005 06:28 PM
    WTB 240D 4SPD BiodieselCleveland W123 E,CE,D,CD,TD,TE Class 4 03-15-2004 06:50 PM
    4spd. from a 240D- How much is it worth? Would it bolt to 5cyl? GermanCarNut W123 E,CE,D,CD,TD,TE Class 1 06-03-2003 01:34 AM
