'76 300D -- won't start after a month away - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 11-15-2009, 11:50 AM Thread Starter
Alvaro_V's Avatar
Date registered: Jul 2007
Vehicle: 1991 350SD, 1976 300D
Hi all,
I went away on vacation for a month and when I came back my 300D wouldn't start. A month ago I had no engine/start issues at all. Symptoms:
On-dash glowplug light works as normal. Battery is still strong and starter seems to engage as long as I hold the key down. Once in a while at the first few attempts, there was the sound of fuel ignition, but only briefly. Now there is no sound of fuel ignition. Clear fuel line near manual fuel pump shows that there is fuel there (I pumped the manual fuel pump a few times to make sure it wasn't a dry line issue).
That's where I am. Fuel seems to be there, battery seems strong enough to turn it over and make the plugs glow... What could be wrong? (Did I possibly flood the engine? I mean, do fuel-injected diesels flood even? I did have that worry at first and left the car alone overnight, but this morning I had the same response.)
Thanks for any help,
AV
Alvaro_V is offline
post #2 of 6 (permalink) Old 11-15-2009, 02:07 PM
79Mercy's Avatar
Date registered: Oct 2006
Vehicle: 1979 280CE
Quoted: 2 Post(s)
Your glowplugs probably are not working. I would chekck for power at each one.
Remember you have the old loop plugs, one burns out then none of them work.
Got any pictures of your W115?
'79 280CE with 226,000 miles
'76 240D 4 speed with 190,000
'85 300D Turbo with 266,000 miles
GONE but not forgotten
'76 300D with 195,300 miles
"83 300D with 174,000 miles
79Mercy is offline
post #3 of 6 (permalink) Old 11-15-2009, 03:46 PM Thread Starter
Alvaro_V's Avatar
merci mercy,
my chilton guide says i need to ground each glow plug with a screwdriver and see if there are sparks. no sparks means bad plug. is that about right?
(i tried putting an pic of the car in my sig, let's see if it works...)
Alvaro_V is offline
post #4 of 6 (permalink) Old 11-15-2009, 03:49 PM Thread Starter
Alvaro_V's Avatar
dangit. try again.
Alvaro_V is offline
post #5 of 6 (permalink) Old 11-17-2009, 08:38 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Don't use a screwdriver, it damages your glow relais.
Use a voltage meter instead. Measure the voltage at each plug.
You can also use a current clamp, current should be between 50 and 55 Ampere.
Govert70227 is offline
post #6 of 6 (permalink) Old 11-17-2009, 10:35 AM Thread Starter
Alvaro_V's Avatar
oh, good thing i ran out of time this weekend or i would have done it wrong. thanks for the tip.
Alvaro_V is offline
1997 E320 parked for 3 month, wont start gonziva W210 E-Class 22 08-22-2009 07:58 AM
1997 E320 parked for 3 month, wont start gonziva General Mercedes-Benz 2 08-04-2009 10:15 AM
2006 ml500 cranks but will not start - no code - at mb service x3 in 1 month!! myml430@yahoo.com W164 M-Class 11 05-16-2009 02:49 PM
85 300d won't start Ed.K W123 E,CE,D,CD,TD,TE Class 4 12-18-2008 08:41 AM
300D doesn't want to start- help! gf70sShow W123 E,CE,D,CD,TD,TE Class 4 12-02-2008 07:58 PM
