» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > General Mercedes-Benz Forums > Vintage Mercedes-Benz
Old 11-06-2009, 11:53 PM   #1 (permalink)
Date registered: Nov 2009
250 se coupe has engine problems
Iam trying to help a friend out on his what I believe to be a mechanical fuel injected 250 se coupe car.
It runs fine thru the upper power band but at idle and start up it hunts it goes high then low on the rpm.
I do not know if it is the injection but someone told me it maybe the idle air compensator or fuel pump or possibly the throttle body positioner sensor.Anybody have any clues.it is a 66 w111 coupe if that helps.
124wagon_boy is offline   Reply With Quote
Old 11-07-2009, 09:53 AM   #2 (permalink)
Vehicle: 64' 220SEc, 72' 300SEL 6.3, 41' Willys coupe, lots of parts
Remote diagnosis and corrective actions are not easily accomplished.
First find someone who knows the motor.
Second powerwash and clean the entire engine compartment and front axle assembly.
Start with a valve adjustment, timing chain check, new valve cover gasket and finally a compression test.
next, new plugs wires points, cap and rotor. set timing.
change all fluids, gas air oil filters.
Only then, can you start even thinking about messing with the fuel injection system.
realize that this FI is a sophisticated analog computer and the last thing to go wrong. but it can.
Many of these cars suffer from neglected, deferred maintenance
Brian O
bostosh is offline   Reply With Quote
Old 12-20-2009, 06:49 PM   #3 (permalink)
Date registered: Dec 2009
Vehicle: 68 MBZ 250se COUPE/81 300 tdt WAGON/86 420sel
the previous post laid out the basics for pre injector repairs. the 259se has a mechanical rack 6 plunger injection set up. when you first start the car it has a small nozel on the air horne which injects a spray of gas to provide combustion which has a history of failure. over time the injection nozle goes bad and causes over fueling and "loping" at idle speeds. i hear the part may be available from gus at pacific fuelinjection in so san francisco. 650 588 8880 he is a good souece for injector pump help gl Dave
have same car as you (my 7th one) and do all work on it myself (73 yrs old)
JJsAtoZatAz@MSN.COM is offline   Reply With Quote
Old 12-20-2009, 07:00 PM   #4 (permalink)
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Run a can of 44k from bg in a full tank. Drive that out, the see what it does. You have a varnished pump and injectors. BTW, there is not a throttle position sensor on that car. It is all mechanical.
renaissance_warrior is offline   Reply With Quote
Old 12-21-2009, 09:27 AM   #5 (permalink)
Grubeguy's Avatar
Date registered: Jan 2006
Vehicle: '73 280SE 4.5, 73 280C (sold), 65 220SEb (stolen), 03 BMW Z4 (upcoming death trap/prison sentence)
Does this car have a computer?
Mine's a totally different car with a different engine, but I had the same issue when I first bought it. I replaced all the vacuum lines and solved the issue. Good luck!
Grubeguy is offline   Reply With Quote
Old 12-25-2009, 11:35 AM   #6 (permalink)
No computer.
Old 12-27-2009, 08:55 PM   #7 (permalink)
Vehicle: '70 280 SE 2.8
Yes, has the car been sitting for any extended length of time that you know of, especially recently? That will help to narrow things down as well.
UCF21 is offline   Reply With Quote
Old 12-28-2009, 02:53 AM   #8 (permalink)
Date registered: Dec 2003
Vehicle: 1989 420SEL, 1965 220S, 2002 Ford Crown Vic Police Interceptor
Think of the fuel injection pump as an analog computer.
Near Manassas Va. '65 220S2002 Ford Crown Victoria Police Interceptor, 89 420SEL
Had '65 220SE, 67 230S, 72 280SE 4.5 Dad had '65 300SE LWB, '65 220SE, '89 300SE
"Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive." C.S. Lewis
wbain is offline   Reply With Quote
Old 12-28-2009, 09:55 AM   #9 (permalink)
cadurning's Avatar
Vehicle: '72 280SE barn find
My '72 280 SE 2.8 engine just started doing the same thing with the idle alternating between a high idle and a low idle when cold. What I found is a small round sol valve that is mounted on the RF fender that clicks at the same time as the idle changes. That sol valve has a vacuum hose that is connected to the intake manifold. I suspect that there is a temp switch that controls that valve. My next quest is to find what switch controls that valve. Change the switch, solve the problem.
The car runs great and when in gear and cold the idle change in imperceptible.
If it's not broke it dosen't have enough features.
cadurning is offline   Reply With Quote
Old 01-02-2010, 03:24 PM   #10 (permalink)
Typically that is the tubular thermometer in the tower on the injection pump. A very easy fix. It is for cold enrichment.
engine problems 220 or 250 mogscrapper Vintage Mercedes-Benz 1 12-10-2006 04:01 AM
'71 250 coupe w/rebuilt engine - CA Car Autobahnfahrer For Sale/Wanted/Trade/Giveaway 1 11-12-2005 08:54 PM
1967 250 SE Coupe for sale in California austinado16 Vintage Mercedes-Benz 3 04-23-2005 01:37 PM
Pictures of my 250 SE coupe Miguel Vintage Mercedes-Benz 12 09-12-2004 12:08 PM
parts for 250 se coupe 1967 Guest (MBNZ) General Mercedes-Benz 0 10-08-2000 08:37 AM
