Heater not blowing hot, where do I start? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-22-2009, 07:59 AM Thread Starter
Date registered: Jul 2006
Hello all, I have a 79 450SL. The heater is not blowing hot. Just looking for idea's what I can check by myself before having to bring it somewhere. Thanks
scrowba is offline
post #2 of 7 (permalink) Old 10-27-2009, 03:37 AM
Date registered: Oct 2009
Have you looked at the heater fan? Its located under the glovebox in front. If it is not turning, you might not get any hot air blowed out...
shad0w is offline
post #3 of 7 (permalink) Old 10-27-2009, 07:24 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
Does it get a little warm after a time or nothing?
Do you get heat if you have it set to Defrost?
GeeS is offline
post #4 of 7 (permalink) Old 10-28-2009, 10:28 AM
Date registered: May 2008
Vehicle: w116 450sel hearse
have you checked cool water?
Gitz is offline
post #5 of 7 (permalink) Old 10-31-2009, 08:02 AM Thread Starter
The blower seams to blow fine. GermanStar, it does not heat up at all even when the defroster is turned on? What is cool water?
scrowba is offline
post #6 of 7 (permalink) Old 10-31-2009, 09:40 AM
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 665 Post(s)
You probably have a bad servo, the big black thing under the hood with four hoses going to it. That is your heater control valve, and if working properly, you should be able to hear it as the system is switched from AC to heat. Servos fail frequently and are rather costly.
GeeS is offline
post #7 of 7 (permalink) Old 10-31-2009, 11:57 AM
sry, my English has gotten a bit rusty, been living abroad to long.
Have u checked if there is enough water in the radiator? It´s only an idiot check, but still worth looking at, before you look at anything else.
Other than that? Does anyone else know if the Sl also has the little pink coloured vacum pump on the Board wall for the heating? like w116 does?
Gitz is offline
    heater always blowing hot wayner118 V-Class 8 10-30-2013 03:28 AM
    300D Heater stopped blowing hot homeslice0229 W123 E,CE,D,CD,TD,TE Class 1 12-28-2007 11:04 AM
    E320 AC was blowing hot, now quit blowing DavidCohen W210 E-Class 11 08-22-2007 02:00 PM
    ac blowing hot air on the side vents?!? HELP, its hot out here.. DCBreed W140 S-Class 6 06-19-2007 12:18 PM
    Scorching hot air blowing; but heater not on!! ronpelham W201 190-Class 7 09-07-2006 05:56 PM
