Help Needed - 83' 300SD - Air line diconnected ???? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-21-2009, 07:21 PM Thread Starter
Date registered: Sep 2009
Hey You guys... Looking to get 83 300SD ... very clean body, etc. From the pix owner send me I can see one Air line disconnected on top of the engine ( pls. look at the pix ). what is this line resp. for ? Can I drive with that line beeing disconnected ?
Thanks again for your kindness...
Keram69 is offline
post #2 of 3 (permalink) Old 10-22-2009, 12:17 PM
christopher1959's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes 300TE Estate Wagon 3.0L 208K miles Smoke Silver/Cream Beige Tex. and others.
Hard to tell exactly from the dark pic, but the arrow is pointing towards the vacuum lines to and from the Vacuum control modulator that controls the shifting of the Automatic Trans. Does the car run and shift ok? Otherwise it looks like the lower arrow is pointing at the crankcase breather vent to the air filter housing,,, very common broken, they harden and break and fall off. Very easy to get a new one and slip it on before driving long distance.
1990 S-124 3.0 Sport Touring Wagen. 218K + Miles
1987 Porsche 911 Carrera 3.2 53K miles !
1971 BMW 2002
1987 BMW 325 IS M-tech
1976 Jaguar XJ12C 5.3 V12 Coupe
2009 Suzuki GZ250
And Remember to always KISS, Keep It Simple Stupid!
christopher1959 is offline
post #3 of 3 (permalink) Old 10-29-2009, 02:43 AM
Govert70227's Avatar
Date registered: Oct 2009
Vehicle: 2000 VW Golf Variant
Quoted: 4 Post(s)
Looks like the vacuum line to the EGR valve.
The 300SD Turbodiesel only uses the switchover valve on top of the valve cover for the EGR.
Govert70227 is offline
    No power to Blower Fuse 83' 300SD Jooknon W126 S,SE,SEC,SEL,SD,SDL Class 0 07-29-2008 01:27 PM
    Location of freeze plug on 83' 300SD sack W126 S,SE,SEC,SEL,SD,SDL Class 1 11-09-2006 10:42 PM
    83' 300SD "Flash to Pass"? AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 3 06-11-2006 08:37 AM
    83' 300SD turboDiesel shuts off?? NAOBG W126 S,SE,SEC,SEL,SD,SDL Class 3 08-29-2003 06:19 PM
    Need 500SL (83') vacuum line routing diagram Greg Fragano R/C107 SL/SLC Class 0 09-09-2002 04:29 AM
