'72 280SE Air filter housing - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 10-16-2009, 02:35 AM Thread Starter
Date registered: Oct 2009
Morning all,
My air filter housing is on the way out, it will only seal on 2 sides now, creating a lovely noise when the car is running.
Looking at the unit, it seems pretty large and I was wondering if anyone had managed to fit a more modern, 3rd party air filter onto their 280SE's?
If it was a straight filter, there wouldn't be a problem, but the 280SE has a secondary pipe, so that causes an issue.
Any advice greatly appreciated!
Thanks
dsan2 is offline
post #2 of 7 (permalink) Old 10-16-2009, 05:06 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Is this a 4.5? If yes, you also have the D-jetronic air temp sensor located in front of the air filter housing to take into consideration.
GGR is offline
post #3 of 7 (permalink) Old 10-16-2009, 05:14 AM Thread Starter
No, this is the 3.5, so no air sensor to contend with
dsan2 is offline
post #4 of 7 (permalink) Old 10-16-2009, 06:33 AM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Well, the 3.5 and 4.5 are basically the same engines both with a D jetronic system and an air sensor on the air filter housing. Is your engine an in-line six cylinders with the air filter housing in front and on the right of the engine bay, or a V8 with a big flat round air filter housing on top of it?
GGR is offline
post #5 of 7 (permalink) Old 10-16-2009, 08:11 AM Thread Starter
in-line six with the housing at the front.
dsan2 is offline
post #6 of 7 (permalink) Old 10-16-2009, 08:24 AM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
The secondary pipe is for the fumes out of the valve cover, I guess. You can replace it with one of these funny kind of mushrooms we see sometimes on american V8s. You can then put some kind of K&N filter in front of the throttle body. But the original system is quite well studied: it sucks cold air in front of the radiator in a location which is under quite some pressure when speeding helping a better filling of the cylinder. Air is then admitted in the round housing where it rotates (hence creating further acceleration) while being sucked through the filter. An aftermarket replacement may end up in some loss of power. I don't know what's wrong with your housing, apart from some clips that may have gone wrong? I would consider repairing it or replacing it by a used one.
GGR is offline
post #7 of 7 (permalink) Old 10-16-2009, 09:58 AM Thread Starter
Wow very useful information, thank you!
will see if it can be fixed, I'm based in South Africa, so Merc tend to charge a fortune here for parts.
Thanks again all
dsan2 is offline
    Air filter housing clive1001blue W126 S,SE,SEC,SEL,SD,SDL Class 9 09-26-2010 02:41 AM
    Air filter housing 4-speed W126 S,SE,SEC,SEL,SD,SDL Class 3 05-13-2008 02:10 PM
    Air filter housing Johnblade R129 SL-Class 0 10-02-2007 05:19 AM
    oil in the air filter housing p100 W123 E,CE,D,CD,TD,TE Class 3 02-19-2007 10:29 AM
    Air Filter Housing. Neo420 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-04-2003 10:51 PM
