'72 250 weird noise - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-13-2009, 05:10 PM Thread Starter
Joshua Lomax's Avatar
Date registered: Jul 2009
Vehicle: 1972 250 saloon
Post '72 250 weird noise
the car is making a weird noise when the accelerator is pushed.
like a "wahhhhhhhhhhhhhhhh" but when it reaches aboout 40 mph it goes away unless you floor it.
it almost sounds like the tires are rubbing. i checked it but nothing is touching...
any thought?
Joshua Lomax is offline
post #2 of 6 (permalink) Old 10-15-2009, 12:34 PM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
Wheel bearings. Front ones are easy to replace and cheap too.
Grubeguy is offline
post #3 of 6 (permalink) Old 10-15-2009, 05:13 PM Thread Starter
bearings....?
then why no sounds when the gas isnt being pressed or when going downhill?
seems like bearings would be a constant sound.
post #4 of 6 (permalink) Old 10-16-2009, 05:15 AM
Grubeguy's Avatar
Quoted: 102 Post(s)
The wahhhhhhhhhhhhhhhh sound gave it away
Grubeguy is offline
post #5 of 6 (permalink) Old 10-16-2009, 05:42 PM Thread Starter
what does the process of removing them and putting them back on consist of?
any special tools i might need?
and should i get all 4 since im going at it?
post #6 of 6 (permalink) Old 10-17-2009, 09:31 AM
Grubeguy's Avatar
Quoted: 102 Post(s)
Ummmmm, let's see if I remeber. Take of the wheel. With a large blade tip screwdriver, pry off the center hub. Remove the brace caliper bu releasing the hex hex nut and bolt, and using a stiff wire or string, secure it away from the wheen housing (so that the brake hose diesn't support the full weight). In the center section of the wheel hub is a nut that basically holds it to the spline - unscrew that with a pair of opened pliers, and the whole brake disk assembly pulls out. You'll see the bearings, with the races still pressed to the hub.
Take a look at the online resources portion of this forum - there should be an article on wheel bearing jobs. If not, let me know and I'll post one.
Reassembly is the reverse ...
Grubeguy is offline
    WEIRD AC Noise elitehassett04 W210 E-Class 10 09-23-2009 09:17 PM
    weird noise netsfan549 W202 C-Class 2 09-16-2009 05:36 PM
    Weird noise help... xmguy W203 C32 AMG, C55 AMG 2 04-21-2008 07:33 PM
    Weird Noise impac_99 W163 M-Class 2 10-20-2005 07:35 PM
    Weird Noise gmata W210 E-Class 2 03-04-2003 06:52 AM
