78' 300D won't start - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-29-2009, 03:56 PM Thread Starter
Date registered: Sep 2009
Apologies for my diesel ignorance! This is my first one...here's where I am at.
Glow plug light on dash went out---wouldn't start.
I replaced the plugs and the strip fuse in the relay (it was frayed).
Light now comes on and the plugs and connecting wires are hot.
Still turns over but won't start.
I traced the fuel lines and replaced a cracked hose, replaced both fuel filters and cleared the line of air.
Same deal: it turns over but won't start.
Battery has a fresh charge.
I am stumped. What do I do next? The local M-mechanic suggested a cliff!
many thanks
PHIL78 is offline
post #2 of 5 (permalink) Old 09-30-2009, 12:43 AM
Braunhilda's Avatar
Date registered: Jul 2008
Vehicle: 1980 300TD
not sure what the history is--did it start before the glow circuit issue?
anyway, i would suspect that either you have not actually completely purged the fuel system of air OR you need to look at injection timing.
Braunhilda is offline
post #3 of 5 (permalink) Old 09-30-2009, 07:39 AM Thread Starter
yes, it was running great before glow plugs went out---Just repurged the fuel lines and turned it over until the battery ran out of juice. Not even a cough like it wanted to start.
Back to the manual to learn about injectors and charge up the battery.
PHIL78 is offline
post #4 of 5 (permalink) Old 10-01-2009, 10:31 AM
christopher1959's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes 300TE Estate Wagon 3.0L 208K miles Smoke Silver/Cream Beige Tex. and others.
If your glow plugs are lighting and you have good Compression? and fuel with no air,,, have you checked replaced BOTH Fuel Filters? You will need a very STRONG Battery,, if you have all this , just try cranking on it while all the while holding the accelerator pedal all the way to the floor,, and see if it does not slowly sputter to life.... as you crank on it do not let off the key until it is runnning on all five....good luck..
1990 S-124 3.0 Sport Touring Wagen. 218K + Miles
1987 Porsche 911 Carrera 3.2 53K miles !
1971 BMW 2002
1987 BMW 325 IS M-tech
1976 Jaguar XJ12C 5.3 V12 Coupe
2009 Suzuki GZ250
And Remember to always KISS, Keep It Simple Stupid!
christopher1959 is offline
post #5 of 5 (permalink) Old 10-07-2009, 06:50 AM Thread Starter
Okay, Back at it today. I swapped out the battery and charged her up. Then went back and noticed when the plugs were heating that #2 was just warm and #1 was stone cold while the other three filaments were glowing red hot. I thought maybe I screwed up the install or the core was dirty so I took out the plugs and wire brushed inside the cylinders---made sure everything was CLEAN. Now same deal, #1 and 2 are not hot. Is it possible that the filament/wire between the plugs can go bad? Why would I not be getting heat to those two plugs when everything is new.
PHIL78 is offline
    Top speed for 78' 300D 64 pony W123 E,CE,D,CD,TD,TE Class 12 07-28-2007 08:18 AM
    78' 300d head for sale... turbodieselguy For Sale/Wanted/Trade/Giveaway 0 05-03-2007 06:35 PM
    Should I buy this 78' 300D Turbo DIESEL? BlackonBlack W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 07:56 PM
    78' 300D! List Of Problems! Morpheus W123 E,CE,D,CD,TD,TE Class 1 06-04-2006 07:24 PM
    Troubleshooting 78' 300D Non-Turbo Morpheus W123 E,CE,D,CD,TD,TE Class 10 06-02-2006 09:53 PM
