Installing Dash Cap - Climate Sensor - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-29-2009, 02:33 PM Thread Starter
Date registered: Sep 2009
Hello - I have just purchased a 79 450SL...Now the adventure begins. I am starting with a dash cap which I have read to be easy. Everything I read says "pull the climate control sensor out" Not so fast - mine appears to be hardwired? I called the dash cap manufacturer for advice and they only said everyone just pulls the hoses off and then trims the opening. Again, mine has wires under the hose and appears to be soldered directly to the sensor. The overall unit appears to be 2 pieces but I dreadfully fear prying too much and cracking the entire unit. Appreciate any thoughts before heading to my mechanic..
79 450SL is offline
post #2 of 3 (permalink) Old 10-06-2009, 10:49 PM
strife2's Avatar
Date registered: Jul 2004
Vehicle: 560SL,380SL
Quoted: 51 Post(s)
Here's the way I remember this...on an 85 SL. the sensor has a top "grate" and the bottom part fits into it, it can be pulled apart. Then, the top part pops off from the top. Once I had the cap EXACTLY where I needed it, I marked the underside of a cap with a paintbrush up through the (now sans sensor assembly) hole in the dash. I deliberately went a little smaller than needed and then adjusted this later when the dashcap was RTV'd down, by trimming with a cable-operated Dremel-like tool. That ABS plastic is VERY tough. You need a very small tool to trim with because there really isn't much room to work with there.
Btw, be careful with the thermistor, it's very delicate. And contrary to what you might read, no, you can't get one with the proper temp/resistance curve from Radio Shack for $2.00.
If you search this site, you will find pictures of this sensor and the (usually deteriorated) hose associated with it.
Homebrew MB First Gear Start!
strife2 is offline
post #3 of 3 (permalink) Old 10-07-2009, 06:42 AM Thread Starter
great - Thanks!
79 450SL is offline
    W126 FS: Gas Cap, Dash Cover, Climate Control Module, and Footrests (Palomino) James560SEL For Sale/Wanted/Trade/Giveaway 3 12-27-2010 03:08 PM
    Dash cap Cyberbach W123 E,CE,D,CD,TD,TE Class 4 08-17-2009 10:10 PM
    after installing new cats, 02 sensor heater circuit codes on both sensor 2s busoptr W163 M-Class 7 07-31-2007 12:18 AM
    Climate Control panel or under dash sensor? houston14 R/C107 SL/SLC Class 3 02-11-2007 09:28 AM
    dash cap installation tex500 R/C107 SL/SLC Class 8 10-17-2004 10:22 AM
