114 cylinder head prob - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-28-2009, 06:30 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
so........ last year had antifreeze smoking from exhaust, changed head gasket. then.... still had antifreeze coming out of exhaust, rebuilt head. now.... still have antifreeze smoking. spoke to a guy who knows about motors and he told me that my head was most likely not rebuilt right and that antifreeze will not escape from the block. is this true or do i possibly have a bad block. any help will be apreciated
thanks
madmanmerc is offline
post #2 of 7 (permalink) Old 09-28-2009, 11:23 PM
wbain's Avatar
Date registered: Dec 2003
The cyl head needs a pressure test. It can also be checked for cracks.
wbain is offline
post #3 of 7 (permalink) Old 09-28-2009, 11:59 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
had the head rebuilt. could it possibly be the block
post #4 of 7 (permalink) Old 09-29-2009, 10:46 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Warped head maybe?
Grubeguy is offline
post #5 of 7 (permalink) Old 09-29-2009, 04:42 PM
Vehicle: 2005 C350, 2002 ML270CDI, 1969 230S, previously 2002 A160, 1985 380SEC ivory, 1983 380SEC grey
Hi madman,
recently I bought a 1969 230 Automatic, 6 cyl carburettor, with "a blown head gasket". The car had good provenance, its original delivery papers, etc.
It turned out to be an expensive exercise!. The head was actually abraded away between cylinders by combustion gases. The concensus from my mechanic and the cylinder head reconditioners was that it was not repairable, as the aluminium alloy had softened due to a previous crack and clumsy rewelding. I found other cylinder heads from wreckers, similar problems and rejection! Eventually I got one good enough to be reconditioned and it was reunited with the block. It cost me about AUD4000, twice what the car is worth!!!
The moral is:- your cylinder head may also be soft in places, and may have blown straight through again. Sorry :-(
I hope you can get the car running again.
kind regards
David
Audiophile_AU is offline
post #6 of 7 (permalink) Old 09-29-2009, 08:21 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
so should i look into getting another head, or should i pull out the block also and get it rebuilt. what i want to do is be sure what the mechanic told me about blocks not ruining is true so i can concentrate on the head
thanks
post #7 of 7 (permalink) Old 09-30-2009, 07:32 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
talked to that mechanic agai. he told me there is no way it could be tha block. i find that strange. coukd it be that a block can not get affected
    w124 300E head & w124 260e cylinder head same? euroamg W124 E,CE,D,TD Class 4 12-03-2008 02:11 AM
    Cylinder Head Replacement jzerres W126 S,SE,SEC,SEL,SD,SDL Class 9 04-23-2008 11:02 AM
    head cylinder jarzen W124 E,CE,D,TD Class 0 10-04-2007 06:12 PM
    cylinder head james124 W124 E,CE,D,TD Class 2 04-08-2007 06:36 AM
    cylinder head kickboxer W126 S,SE,SEC,SEL,SD,SDL Class 9 07-02-2006 08:38 PM
