Brake system failure 1974 450SEL - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-27-2009, 12:27 PM Thread Starter
Date registered: Sep 2009
Can anyone tell me why my brake pedal goes to the floor after a day of driving? My mechanic replaced the master cylinder twice, no fluid leaking, etc.
He thinks it has something to do with heat off the manifold?
We could sure use some help.
St. Lucie Appraisal is offline
post #2 of 10 (permalink) Old 09-27-2009, 10:05 PM
wbain's Avatar
Date registered: Dec 2003
You and you're mechanic will have to check all the brake lines, flexible hoses and calipers for leaks.
wbain is offline
post #3 of 10 (permalink) Old 09-28-2009, 06:15 AM Thread Starter
There are no leaks anywhere.
Could there be some sort of slave cylinder or secondary cylinder that's failing?
post #4 of 10 (permalink) Old 09-28-2009, 08:09 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
How's your booster?
flyboyike is offline
post #5 of 10 (permalink) Old 09-28-2009, 10:19 AM Thread Starter
If I lose vacuum to the booster it will be a hard pedal, right? Mechanic does not think it's a booster. The fluid is topped off, no leaks. Is there a dump valve?
post #6 of 10 (permalink) Old 09-28-2009, 11:58 AM
flyboyike's Avatar
Quoted: 68 Post(s)
What if you lose the diaphragm in the booster?
post #7 of 10 (permalink) Old 09-28-2009, 11:25 PM
wbain's Avatar
Has all the brake fluid been changed? Brake fluid absorbs water and contaminated brake fluid has a lower boiling point.
wbain is offline
post #8 of 10 (permalink) Old 09-29-2009, 04:44 AM Thread Starter
May I ask if there is any difference in appearance once the brake fluid absorbs water, similar to oil and water, perhaps?
post #9 of 10 (permalink) Old 09-29-2009, 10:13 AM Thread Starter
To update you, the car has brakes now. Could be that the fluid, diaphragm or whatever has cooled off.
Perhaps a different brake fluid? DOT 3 in there now I believe.
post #10 of 10 (permalink) Old 10-06-2009, 03:57 PM
Date registered: Jun 2009
The heat of the manifold has nothing to do with the brake system. Your Mercedes most likely needes to be flushed out several times over a course of time. A one time bleed out won't do it especially if the car has been neglected since day one. Not saying it happened to you. It happened to me.
I replaced all brake rotors, pads and the master cylinder went out after that.
It will help if I flush the brake system again in a couple of months.
I have a knack for this stuff.
GenBiltstein is offline
    2001 C240 Brake light failure leading to ESP/BAS Failure lxshk Audio & Telematics Forum 1 08-04-2008 10:54 PM
    1974 450SLC Brake system rebuild. Jonathan Fennell R/C107 SL/SLC Class 21 11-29-2007 03:02 PM
    1974 450SEL with 971K miles Kalifornia W116 S, SE, SEL, SD Class 1 08-31-2006 01:30 AM
    Value of 1974 450sel? kaz1961 Vintage Mercedes-Benz 2 10-22-2004 03:05 AM
    Brake system failure indication Tom Hock W163 M-Class 11 06-26-2004 10:06 AM
