Help!w114/116 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-27-2009, 03:44 AM Thread Starter
Date registered: Jan 2009
Vehicle: sel 450 1975 ;280 ge 1982
Help!w114/116
hi!could any one can tell me is it big job( posible) put v8 engine from w116 to w114 280e coupe!i have w116 with bad shell and w114 with no run engine ,but body is solid.help please with adwise!
thank you!
zLusis is offline
post #2 of 4 (permalink) Old 09-27-2009, 05:05 AM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
It has been done before, I believe it is rather simple, especially if both cars have the same injection system.
GGR is offline
post #3 of 4 (permalink) Old 09-28-2009, 09:53 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
The issue is space in the 114. You'll have to do some cutting and fabrication of custom motor mounts. Anything and everything has been done before, as long as you have the mechanical engineering skills...
Grubeguy is offline
post #4 of 4 (permalink) Old 09-28-2009, 10:41 AM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
I don't know about clearance issues with the firewall, and the brake booster. But the W114 shares a lot of chassis elements with the r107 including front subframe, ans also perhaps front chassis rails. r107s also came with V8s. Transplanting a V8 (M116 or M117) is a matter of taking the r107 V8 engine brackets (they may also be the same on the W116s) and it's a straight fit on the W114 engine mounts and front subframe.
GGR is offline
    116.961 and 116.963 difference B71ZZZ W126 S,SE,SEC,SEL,SD,SDL Class 26 06-02-2012 03:49 PM
    w 116 280se g.w.b W116 S, SE, SEL, SD Class 2 01-11-2007 01:29 PM
    Difference between 116.980 and 116.981 engine kdm7005 General Mercedes-Benz 1 12-03-2005 07:40 PM
    This is what I want my 116 to look like MrNemo Vintage Mercedes-Benz 13 08-01-2005 02:09 AM
    116 Taillights krock Vintage Mercedes-Benz 4 06-11-2005 09:41 PM
