thermostat and waterpump question... - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-26-2009, 10:40 AM Thread Starter
benz280se's Avatar
Date registered: Jan 2007
Vehicle: 1974 280se w116, 1986 560sec
i would just like to know when do you know it's time to change the water pump and the temp gauge? i have a w116 280se non air conditioned. and i just noticed the other day the temp runs what seems a little high to me, it isn't overheating but it looks close i never noticed it before. i just don't want to blow the engine it runs so good. any suggestions?
benz280se is offline
post #2 of 6 (permalink) Old 09-28-2009, 08:56 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 102 Post(s)
From your water pump, can you hear anything with the engine running? If your engine runs hot, I'd look at the thermostat first. Have you ever had your radiator recored or cleaned?
Grubeguy is offline
post #3 of 6 (permalink) Old 09-28-2009, 11:37 PM Thread Starter
benz280se's Avatar
i have listened to the engine and everything runs pretty quiet for a 35yo car. the car hasn't overheated yet but it is running close to the limit. i flushed out the old antifreeze and put in new stuff, 50/50 mix. i guess i'll replace the thermostat next and see what happens.i'll post the results.
post #4 of 6 (permalink) Old 09-29-2009, 09:45 AM
Grubeguy's Avatar
Quoted: 102 Post(s)
Well, how hot is hot? Like, at the upper limit of your temp gage? Can your hear your aux fan come on?
Grubeguy is offline
post #5 of 6 (permalink) Old 09-30-2009, 11:34 PM Thread Starter
benz280se's Avatar
it gets pretty close it gets to the line below 120 it hasnt gotten all the way to 120 yet but it bounces in that space i guess i'll have to take a pic tommorow cause i dont know enough of how to explain it. i don't know about an aux fan i dont think this car has one of those only fan i see is the one behind the radiator and that spins no matter what.
post #6 of 6 (permalink) Old 10-03-2009, 01:11 PM Thread Starter
benz280se's Avatar
i think i may have found the problem, i went over the cooling system and found a leaking hose. it wasn't a large leak but enough to drip over the last week of normal driving down to 3/4 of radiator fluid. i tightened the hoses and took it on the highway and it peaked for a minute then settled down. but i do need to change all my hoses uugh.
    '95 E300 DIESEL thermostat question sbaert W124 E,CE,D,TD Class 0 10-22-2008 09:34 AM
    Thermostat question daryn R/C107 SL/SLC Class 6 07-19-2008 12:54 PM
    thermostat question w140king W140 S-Class 5 02-18-2007 12:46 AM
    A thermostat question nos_com71 W140 S-Class 4 01-22-2007 02:09 PM
    Thermostat Replacement Question... bse500sel W126 S,SE,SEC,SEL,SD,SDL Class 4 01-14-2005 10:20 AM
