6.9 vs 3.5 rear end question - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-24-2009, 10:05 AM Thread Starter
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 104 Post(s)
I've got a '71 300SEL with a more or less shot 3.5 engine. Sometime in the future, I'm looking at swapping my 108's 4.5 into it, but wouldn't mind finding a 6.9 engine/tranny to put in instead. The question is, can the 3.5 rear end take the torque of a 6.9 engine?
What made the 6.3 rear ends different than the ones for the 4.5's?
Grubeguy is offline
post #2 of 6 (permalink) Old 09-24-2009, 12:00 PM
christopher1959's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes 300TE Estate Wagon 3.0L 208K miles Smoke Silver/Cream Beige Tex. and others.
Only the ratios.. I believe...
1990 S-124 3.0 Sport Touring Wagen. 218K + Miles
1987 Porsche 911 Carrera 3.2 53K miles !
1971 BMW 2002
1987 BMW 325 IS M-tech
1976 Jaguar XJ12C 5.3 V12 Coupe
2009 Suzuki GZ250
And Remember to always KISS, Keep It Simple Stupid!
christopher1959 is offline
post #3 of 6 (permalink) Old 09-24-2009, 08:20 PM
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
The 6.3 had a reinforced homokinetic joint to transfer the movment from the differential to the right wheel shaft. It also had a LSD. I saw some 3.5 and 4.5 with and some without that reinforced joint. LSD was an option on the 3.5 and 4.5. To check the type of joint you have you can push the rubber between the right wheel tube and the center casing. If you see a connection like a trans shaft universal joint it is not reinforced.
You can fit a 6.9 but this will be a lot of work. A 5.0 or 5.6 M117 will be much easier and lighter. I got both a W111 Coupe fitted with a 6.9 and another one with an euro 300 hp 5.6. The latter is nearly a straight fit while the 6.9 required a lot more fabrication (engine and trans mounts relocated, custom exhaust headers etfc.). with a 5.0 or 5.5 M117 the best is to use 560SL exhaust manifolds or 500 SL/C tri-Ys if you find some.
GGR is offline
post #4 of 6 (permalink) Old 09-24-2009, 09:33 PM
wbain's Avatar
Date registered: Dec 2003
Quoted: 4 Post(s)
You believe incorrectly. There are major changes.
wbain is offline
post #5 of 6 (permalink) Old 09-25-2009, 12:24 AM Thread Starter
Grubeguy's Avatar
Quoted: 104 Post(s)
Originally Posted by GGR View Post
You can fit a 6.9 but this will be a lot of work. A 5.0 or 5.6 M117 will be much easier and lighter. I got both a W111 Coupe fitted with a 6.9 and another one with an euro 300 hp 5.6. The latter is nearly a straight fit. with a 5.0 or 5.5 M117 the best is to use 560SL exhaust manifolds or 500 SL/C tri-Ys if you find some.
OK, sounds interesting. I'm not too familiar with other Benz engines - what model has the 5.6 engine? The 560SL's?
Grubeguy is offline
post #6 of 6 (permalink) Old 09-25-2009, 04:19 AM
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Warren,
apart from the homokinetik joint and the LSD that the 3.5 and 4.5 may also have, and of course the ratios, I do not see other differences in the rear axles.
The M117 started as the 4.5, and went on evolving with an alloy block, bigger bore and stroke. But basically it's the sam engine. You keep your 3.5 engine mount brackets and trans mount, 450 SL exhaust manifolds and you are in business. Depending on the version you chose, the challenge may be more on the side of the elctronics.
GGR is offline
2 x M117 engines 2x 3 Speed Auto R107 v8 rear end and W108 v8 rear end alabbasi For Sale/Wanted/Trade/Giveaway 1 06-25-2008 12:14 PM
Diesel Question: Soot on Rear End pinbill W123 E,CE,D,CD,TD,TE Class 3 03-15-2008 03:28 PM
2:88 rear end question. DieselKraut W123 E,CE,D,CD,TD,TE Class 7 02-14-2007 10:59 AM
changing rear end question 560sec W126 S,SE,SEC,SEL,SD,SDL Class 0 05-11-2004 02:21 PM
rear end fluid question 90secowner W126 S,SE,SEC,SEL,SD,SDL Class 5 02-02-2004 09:43 PM
