HELP! Broken belts! ASAP! - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 09-25-2009, 05:44 AM
Date registered: Aug 2009
Quoted: 53 Post(s)
Should be, from the engine out, alternator, power steering and then A/C. The double pulley on the alt is just a "standard" pulley installed by the rebuilder as the alternator fits about a gadzillion different cars.
I have seen the power steering belt on the outside depending on the mounting bracket and chassis.
The engine number I am referring to will be the 130-xxx.xx (or 110-xxx or 117.xxx) before the engine serial number. The number you gave is the serial number which you use for when they state, "from engine serial # on"
Mike D is offline
post #12 of 15 (permalink) Old 09-26-2009, 12:20 PM Thread Starter
Joshua Lomax's Avatar
Date registered: Jul 2009
Vehicle: 1972 250 saloon
i believe its 114.011
but i think your last post should help!
Joshua Lomax is offline
post #13 of 15 (permalink) Old 09-26-2009, 12:48 PM
Quoted: 53 Post(s)
The 114 is the chassis number. The engine number will be on the left hand side of the engine below and behind the distributor. If the car is a 6 cylinder it should start with a 130-xxx.
Mike D is offline
post #14 of 15 (permalink) Old 09-26-2009, 05:59 PM Thread Starter
ah, will check when the massive storm passes, lol
post #15 of 15 (permalink) Old 09-29-2009, 06:54 PM Thread Starter
ok the engine number is : 130.016.26.01
i have went to oreilys and bought the fan and alternator belt. it will not fit. it is too loose.
the power steering goes to the crank.
the ac/ilder/crank fits.
i am stuck and i need help fast.
    Belts, how many countrylanelana W123 E,CE,D,CD,TD,TE Class 5 08-31-2007 06:16 PM
    Is it hard to install drive belts S/c belts? Mark600RRBryant R170 SLK-Class 1 09-12-2005 04:26 PM
    belts german450sel Vintage Mercedes-Benz 4 09-17-2004 04:35 PM
    belts... Eric W126 S,SE,SEC,SEL,SD,SDL Class 10 08-08-2003 02:55 PM
    Anyone know where I can get colored seat belts? Like the custom porsche belts? Long R170 SLK-Class 1 04-29-2001 04:24 PM
