W114 Arm Rest! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-16-2009, 06:46 PM Thread Starter
74benzo's Avatar
Date registered: Sep 2009
Vehicle: '74 280
W114 Arm Rest!
Does anybody know how to remove the front arm rest off a W114?
74benzo is offline
post #2 of 5 (permalink) Old 09-18-2009, 05:00 AM
Date registered: Aug 2009
Quoted: 66 Post(s)
The driver's door armrest has 2 large Phillips headed screws on the lower half. They are buried deep in the recesses. The passenger door (with the long additional handle part) have 2 screws in the same spot and one underneath the chrome trim piece on the very front. The cap pops off using a flat blade to get access to the screw.
The center arm rest has to be removed from inside the passenger seat. Remove the passenger seat's rear panel for access to the retainer.
Mike D is offline
post #3 of 5 (permalink) Old 09-18-2009, 10:12 AM Thread Starter
74benzo's Avatar
Vehicle: '74 280
I was talking about the one between the front seats?
74benzo is offline
post #4 of 5 (permalink) Old 09-18-2009, 12:15 PM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
I know how to remove only part of it. (This a project I'm working on - to ADD the armrest to my car off of a parts car). The armrest pivots on a rod coming out of the passenger seat. On the side of the armrest closest to the driver's seat there is a plastic cap covering the shaft. It's eliptical and about 2" x 3". It pops off. Take off the plastic cap. Under that you will find what looks like a piece of threaded pipe inside that has a disk threaded onto the pipe like a big nut, but it isn't 6-sided. It has a set screw in it. Losten the set screw. (hex head). Then the disk will unscrew off the threaded pipe-like shaft. When that comes off you can slide the armrest off and some of internal shaft stuff will come with it. That gets the arm rest out. You still have the rest of the shaft and what it mounts to (on the passenger seat) to deal with. I haven't gotten that far yet. I have three arm rests and one seat with the bracket in my garage and I need to take apart the doner seat to see how it works and then re-assemble it in my car.
Scoot is offline
post #5 of 5 (permalink) Old 09-18-2009, 10:58 PM Thread Starter
74benzo's Avatar
Vehicle: '74 280
Thanks, the rod that holds it on broke or something and it like points down now so I'm probably gonna have to replace that.
74benzo is offline
    back arm rest mbe240 W210 E-Class 4 04-20-2009 12:59 PM
    Head Rest and arm rest on drivers seat edwardgwright W126 S,SE,SEC,SEL,SD,SDL Class 1 06-10-2008 12:47 PM
    looking for an arm rest nntp W140 S-Class 6 12-25-2007 01:02 AM
    v class arm rest toyyorky For Sale/Wanted/Trade/Giveaway 0 07-04-2007 02:17 PM
    arm rest Jippi W201 190-Class 2 08-01-2006 05:27 PM
