1973 SE280 4.5 Hazard Lights (Flasher) Relay Replacement - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-11-2009, 11:03 AM Thread Starter
Date registered: Sep 2009
Vehicle: 1973 MB 280SE
Hi,
I bought a replacement relay to fix the turn signal blinking too fast issue and I want to install it myself. Does anyone know where the relay is located on my car? I read it is somewhere behind the dash. I looked around but couldn't find it. The hazard light switch is a big red square button under the speedo, is this where the relay is located? How do I get to it?
Thank you for the tips!
rberd is offline
post #2 of 9 (permalink) Old 09-11-2009, 11:14 AM
Ed Mclass's Avatar
Vehicle: 90 300 SE ,85 300 GD
It is either on the firewall under the hood or over your left knee when you sit in the driver's seat. If under the dash you must remove the trim panel under the dash.
Ed Mclass is offline
post #3 of 9 (permalink) Old 09-12-2009, 12:57 AM
Eirik 400 SE's Avatar
Date registered: Jan 2008
Vehicle: 1973 W115 200 /8
Turn ON the flasher, and listen where the clicking-sound comes from..... ?
1991 W140 400 SE - SOLD !!
1973 W115 200 -For sale as project.
Eirik 400 SE is offline
post #4 of 9 (permalink) Old 09-12-2009, 04:50 AM
Ed Mclass's Avatar
Turn Signal
If your turn signal blinks too fast one of your bulbs is out. This is usually one of the rear bulbs and they are easily replaced.
post #5 of 9 (permalink) Old 11-08-2009, 06:25 PM
Date registered: Nov 2009
Turn signal Relay on the early model 450 SL - SLC
Turn signal Relay on the early model 450 SL - SLC is in the left Dash behind the Gage cluster. Just replaced the one on my 1975 450SL and yes I looked in all the other places Posted first.
Thanks
Harleyrds2 is offline
post #6 of 9 (permalink) Old 11-09-2009, 11:21 AM
Date registered: Jun 2007
Vehicle: 2005 SL 55 "k" 26K 1967 250 SL ?K 1984 500 SEC 242K http://www.flickr.com/photos/mercebman/
Quoted: 15 Post(s)
73 350/450 sl relay is under the console.
hilld is offline
post #7 of 9 (permalink) Old 11-09-2009, 04:00 PM
Sorry but the flasher relay is not in the console or part of the Flasher switch.
In all three of my cars it is behind Instruments cluster in the left side of the dash.
My cars are a 75 450 SL - 73 450SLC and 73 280SEL the only one of my cars this is not true on is my 65 190C it has a different flasher.
post #8 of 9 (permalink) Old 11-09-2009, 05:42 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
Have you checked for a burned out bulb? It's a lot simpler than replacing the relay, and it's more likely the cause of your problem.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
post #9 of 9 (permalink) Old 11-09-2009, 06:14 PM
No Sorry all bulbs are working - it is a bad flasher relay - I have 3 cars so I pulled the 2 other units - unit 1 made a noise like a buzzer and lights remained lit but not flashing. unit 2 made a very rapid flashing like a strobe lite, and unit 3 worked normally.
So these units can fail and make buzzer like noises and flash fast with all bulbs working.
I leaned some new things with this adventure.
Thanks for the info
86 560SL hazard flasher location? KC560SL R/C107 SL/SLC Class 5 09-22-2015 04:26 PM
Turn signal/hazard flasher Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 3 03-24-2007 03:28 AM
Clicking noise in console (hazard flasher relay), battery drain. Gvigorus W123 E,CE,D,CD,TD,TE Class 11 02-27-2006 11:50 PM
1973 450SL Flasher Relay Connections mbslns R/C107 SL/SLC Class 2 10-14-2005 07:12 PM
Location of Signal/Hazard Flasher Relay in '75 450SL bondavi R/C107 SL/SLC Class 12 09-09-2005 09:09 PM
