1973 450SL stalls - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-07-2009, 01:31 PM Thread Starter
Date registered: Sep 2009
Vehicle: Mercedes 450SL 1973
1973 450SL stalls
Good day to all!
My 450SL goes great exept when I'm in town, after a few red lights it stalls and it's hard to restart. The only way the engine will start is, if I put the gas pedal to the floor and after the engine goes, a big cloud of black smoke comes out the exaust and got to keep the gas pedal almost to the floor to burn excess fuel, after all that the engine idle around 1400 rpm. No problems at highway speed, on hard accelerations or cold starts. Have any ideas what could cause that?
Thanks in advance for your help!
DKG25 is offline
post #2 of 5 (permalink) Old 09-07-2009, 05:34 PM
Administratoris Emeritus
GeeS's Avatar
Vehicle: 2021 SL770
Quoted: 735 Post(s)
Check the manifold pressure sensor...
GeeS is offline
post #3 of 5 (permalink) Old 09-08-2009, 09:51 PM Thread Starter
1973 450SL stalls
I have some skills in mechanic but, I don't have the "do it your self" book of my car. Can you or someone else please tell me where the manifold pressure sensor is situated?
Thanks for your help!
DKG25 is offline
post #4 of 5 (permalink) Old 09-10-2009, 06:53 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
It's on the left fender, with wires and a vacuum hose running to it from the back of the intake manifold. Be sure that the hose is good.
The only thing you can check is the resistance across the primary and secondary windings. Unplug the connector and measure the primary on the outside terminals. It should read approx. 90 ohms. The secondary, across the inside terminals, should read approx. 350 ohms.
You should also check the air temp sensor in the air cleaner. There should be 300-400 ohms across its terminals. The water temp sensor in the intake manifold should show about 325 ohms with the engine warmed up. If either of these sensors are giving bad readings or are not connected, the brain can go rich, which sounds like what is happening.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #5 of 5 (permalink) Old 09-14-2009, 04:46 PM Thread Starter
I did'nt check the manifold pressure sensor, but the problem is repared; it was an hose-clip on the fuel line near the engine, I was losing pressure in the fuel line causing the engine to stall
Thanks for your help anyway guys
DKG25 is offline
    1973 450SL lfedje R/C107 SL/SLC Class 37 08-15-2011 08:43 PM
    Wtb:1973 450sl NormanB For Sale/Wanted/Trade/Giveaway 3 03-02-2009 02:04 PM
    1973 450sl won't start stage2 R/C107 SL/SLC Class 7 05-20-2008 07:45 PM
    Hardtop For 1973 450sl jerryatric Vintage Mercedes-Benz 5 12-10-2006 08:48 AM
    Should I keep this 1973 450SL? DeidreB R/C107 SL/SLC Class 2 06-13-2004 10:10 AM
