1977 fuel pump question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-29-2009, 07:09 PM Thread Starter
Date registered: Aug 2009
What amount of pressure (LB's) is my fuel pump supposed to be producing? I know American made stuff is 75, but the regulator valve seems to be causing low pressure.
If I have to replace the pump, can I use something else instead of paying the $225 for a new one?
benzrebuild is offline
post #2 of 3 (permalink) Old 08-29-2009, 07:10 PM Thread Starter
By the way the car in question is a 1977 280 CE
post #3 of 3 (permalink) Old 09-05-2009, 06:55 AM
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
The Bosch pumps on these systems produce 35 to 40 PSI pressure with a normally functioning pressure regulator.
I have been able to use bosch pumps that look similar (fittings and size) of Volvos, BMWs, Saabs or anything from this vintage that came with the Bosch fuel injection system.
These aftermarket pumps are on Ebay new between 40 and 50 dollars.
unimoged is offline
    Fuel pump question TMV G-Class 2 07-19-2008 01:34 PM
    Fuel Pump Question dieselbenzfan123 W123 E,CE,D,CD,TD,TE Class 3 04-23-2008 10:00 PM
    fuel pump question GENEVA W126 S,SE,SEC,SEL,SD,SDL Class 0 03-03-2007 06:56 PM
    Fuel Pump/Pressure Question Winner172 W163 M-Class 6 01-06-2006 12:31 PM
    fuel pump question janos_z W126 S,SE,SEC,SEL,SD,SDL Class 6 10-31-2003 07:30 PM
