w123 mixture adjusting problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-27-2009, 05:34 AM Thread Starter
Date registered: Oct 2007
hi guys i have w123 m115 stromberg cd 175 when i try to lean the mixture by tightening the screw under the fuel bowl it stay rich or make a very slight change in the mixture and splutters on very low rpm i sent the car to a mechanic and he adjust it in 5 min but the acceleration is weak and again when i try to adjust it it didn't make a big difference and the screw became heavy in some turns and became ligh again so what is the problem?
shoudy2005 is offline
post #2 of 2 (permalink) Old 09-04-2009, 04:35 AM
unimoged's Avatar
Date registered: Dec 2008
Vehicle: 2004 S500. 2000 CLK430 Cab, 1999 C43 AMG. 1999 S500. 1999 S320. 1977 230 4 spd, 1972 280SEL 4.5
make sure that the rubber diaphram in the carb is not cracked. That will cause weak acceleration and mixture issues.
unimoged is offline
    Adjusting Fuel Mixture at 2500< guarddog W126 S,SE,SEC,SEL,SD,SDL Class 3 09-27-2007 04:34 PM
    W123 Valve Adjusting Wrenches pracklam For Sale/Wanted/Trade/Giveaway 0 08-04-2007 03:46 AM
    Adjusting the Fuel mixture superman_006 W201 190-Class 2 05-16-2007 08:01 AM
    adjusting fuel air mixture ratio william.wood W126 S,SE,SEC,SEL,SD,SDL Class 5 11-11-2005 12:25 PM
    Adjusting the air/fuel mixture ! hyprr1 W124 E,CE,D,TD Class 0 05-18-2005 08:03 AM
