Air suspension questions - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 08-21-2009, 01:51 AM Thread Starter
Date registered: Apr 2009
I am the owner of a 1962 mercedes 190c 4spd. I am really debating; pretty much convinced I want to put air ride into it. I have done some research, and heard it was fairly easy to get a system on there. Replace the coils run your lines and your on the home stretch. But here comes the hard part. Find a kit that will fit. What do I buy and from where. Heard not to buy from
PLease help me out!
eclipse_22 is offline
post #2 of 8 (permalink) Old 08-21-2009, 01:54 PM
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
Forget it, first, it is not easy, second it is a calibrated system, i.e. you would have to re-engineer the proportioning valve.
renaissance_warrior is offline
post #3 of 8 (permalink) Old 08-22-2009, 10:34 AM
Consider a W109 either in the 4.5 version or 6.3
4.5 is a more practical motor, the 6.3 is the monster.
Brian O
bostosh is offline
post #4 of 8 (permalink) Old 08-22-2009, 10:44 PM
wbain's Avatar
Date registered: Dec 2003
Please don't bother with air suspension of any kind. It would be best to rebuild your wziating coil spring suspension, new bushings, kinkpin overhaul, engine and trans mounts, drivehasft flexdisk, center bearing, rear axle bushings and a brake overhaul. New Bilstein shocks would be good too.
Your model is not a powerful car and it's meant for economy.
The air suspensioned cars, the W109 and W112, are designed and built with air suspension. The components are hard to find now and expensive. One benefit of the factory system is it is completely automatic, which means you don't have to make any adjustments unlike the add on ones where you have to run the pump and manually adjust the height.
wbain is offline
post #5 of 8 (permalink) Old 08-23-2009, 11:25 AM
Date registered: Feb 2008
Vehicle: vito 120 cdi
I would guess you mean to customise the car and not retro fit OE merc stuff. if you live in the UK check out the latest 'Retro cars' mag there is a fab merc in there
steel-jaw-sasha is offline
post #6 of 8 (permalink) Old 08-24-2009, 11:50 PM Thread Starter
so I shouldn't even bother customizing the car? Are you trying to say it won't work and just end up falling apart. I don't wanna go radical with it. Just have a minor lower and more comfortable stance on the car.
post #7 of 8 (permalink) Old 08-25-2009, 10:38 AM
christopher1959's Avatar
Date registered: Jul 2007
Vehicle: 1990 Mercedes 300TE Estate Wagon 3.0L 208K miles Smoke Silver/Cream Beige Tex. and others.
You could I suppose remove all the original Air suspension parts from a 60's fintail W112 300SE which came from the factory with Air suspension,, and they may bolt directly onto to your fintail.. but what a nightmare, cannot fathom why anyone would want to,,take a good simple reliable car and turn it into a fragile finicky trickster. Why not just go and buy something with EAS already on it?
1990 S-124 3.0 Sport Touring Wagen. 218K + Miles
1987 Porsche 911 Carrera 3.2 53K miles !
1971 BMW 2002
1987 BMW 325 IS M-tech
1976 Jaguar XJ12C 5.3 V12 Coupe
2009 Suzuki GZ250
And Remember to always KISS, Keep It Simple Stupid!
christopher1959 is offline
post #8 of 8 (permalink) Old 08-25-2009, 06:12 PM Thread Starter
    Can you without problems change the V-class air suspension to spring suspension? kimberly V-Class 5 07-12-2010 03:30 PM
    Please help with suspension questions ...... Cancer_Researcher W210 E-Class 3 07-12-2009 11:35 AM
    Suspension questions... unlukky C208/A208 CLK-Class 1 02-20-2008 10:37 AM
    AIR PIPES to air suspension rb2 V-Class 2 03-09-2007 07:43 AM
    Can you change the air suspension from a V-Class to Spring suspension? kimberly General Mercedes-Benz 2 11-16-2006 02:35 AM
