Replace starter cable 1968 200D - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-17-2009, 08:49 PM Thread Starter
Date registered: Aug 2009
Vehicle: 1968 MB 200D Manual
Post Replace starter cable 1968 200D
Hi, had a cable break on me. Any know how to pull the starter lever out of the dash, I can't seem to find any access to this.
Thank for your help!
drettig is offline
post #2 of 3 (permalink) Old 08-24-2009, 02:03 PM
Date registered: Jun 2004
Quoted: 17 Post(s)
Is that a W110 or a W114/115? Either one should be the same process. You need to remove the complete switch unit. First, unscrew the knob. Second, unscrew the chrome nut/bolt/bezel under the knob. There probably is a special tool for getting the nut off without buggering up the nut, but I haven't seen one. After the nut is off, you can push the unit back and remove it from below. Then you can take the cable off.
If I remember right, there is a small cable going from the key switch to the starter switch for some kind of interlock mechanism. It can be easily detached from the key switch or starter switch, can't remember from which though.
KCM is offline
post #3 of 3 (permalink) Old 08-31-2009, 04:18 PM
Date registered: Jul 2009
Vehicle: 1974 Mercedes-Benz 240D
Send a message via Yahoo to NixonSinatra
I think I had this same thing happen, though not sure if the cable broke, or simply the piece (?) which secures in into the dash. Pulled out fine upon startup (or so I thought), however, when I went to push it back in to shut the car down, it would not correctly push back in. I couldn't figure out how the heck I was going to get the car to shut off? Finally, in a fit or rage (panic) I hit in good and hard and the car finally shut off.
Does that sound similar? I wonder if this too could be a broken cable, or some other piece of the pull starter?
NixonSinatra is offline
    how to replace a starter on a ml430 KAYLASML W163 M-Class 4 05-13-2015 07:42 PM
    Battery to starter cable bluecollarpilot R/C107 SL/SLC Class 7 02-08-2008 11:05 AM
    Anyone ever replace a starter? SpeedDemon R129 SL-Class 15 01-30-2007 07:51 AM
    Alternator/Starter/Battery cable issue Gvigorus W123 E,CE,D,CD,TD,TE Class 26 11-10-2005 01:21 AM
    replace starter on 560 SL Guest (MBNZ) General Mercedes-Benz 0 02-24-2002 04:03 PM
