Flywheel question - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 08-01-2009, 08:45 AM Thread Starter
GGR
Date registered: Apr 2006
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Flywheel question
Hi all,
The other day I took a M116 3.5 flywheel for the contact surface with the clutch disk to be ground as it was not even. I then took it to another workshop to have the contact surface with the pressure plate recessed in order for the distance between these two surfaces to be within specs ie 3.8 mm. The problem is that the second workshop did not make it to put the flywheel exactly into the same plan as the first workshop and therefore there is a difference of 0.001 inch between the two plans. In other words, the contact surface with the clutch disk is not exactly parallel to the contact surface with the pressure plate, and the difference is 0.001 inch (or 0.025 mm) over the clutch disk diameter. The first workshop told me this was negligible and that the action of the clutch disk will grind the difference.
I already had some problems with a new clutch vibrating in the past (the flywheel had not been resurfaced) and had to re-dismantle everything. I would not like the same thing to happen this time. Should I have the contact surface with the clutch disk corrected, knowing that the flywheel is already (nearly) out of tolerances and that I may have to have it rebalanced (time and money), or should I just fit it like this?
Thanks!
GGR is offline
post #2 of 4 (permalink) Old 08-02-2009, 11:31 AM
Date registered: Apr 2009
Vehicle: Current: 1987 560 SEC US, former factory trained MB tech 10 years, owner of 14 others.
That is not enough to be a problem. It will wear in, and each part is already balanced.
renaissance_warrior is offline
post #3 of 4 (permalink) Old 08-04-2009, 11:17 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
I concur - less than a quarter of a millimeter isn't much ...
Grubeguy is offline
post #4 of 4 (permalink) Old 08-04-2009, 11:31 AM Thread Starter
GGR
Vehicle: W111 Coupe
Quoted: 19 Post(s)
Thanks to you both. It'll save some work imeand money.
GGR is offline
    Need help with flywheel TyMad101185 W202 C-Class 8 11-07-2009 09:31 AM
    quick transmission/flywheel question w123-w126 md300cd General Mercedes-Benz 0 06-08-2008 01:54 PM
    Stuck flywheel MasterWangg W123 E,CE,D,CD,TD,TE Class 2 11-01-2006 08:48 AM
    Now the flywheel?? Tom Deckowski G-Class 7 03-10-2004 12:34 PM
    Lightened Flywheel??? Guest (MBNZ) W201 190-Class 5 06-07-2002 09:53 AM
