turn signal relay - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-27-2009, 12:23 PM Thread Starter
Rauchen's Avatar
Date registered: Jul 2008
Vehicle: 1971 Mercedes 280sel (w108)
turn signal relay
the flasher/turn signal relay went out on my 71 108. the wiring harness for this has 6 plugs. I was wanting to replace the original relay with a generic "Buss" flasher relay with 3 prongs. The OEM replacement is $120, that is why I want to go this generic way. I just can't seem to figure out how to configure the wiring. all I know is which pins have continuous 12v. Any one ever done this or knows the wiring on that harness? I haven't had the car out for a week now, cause the blinkers don't work...it's driving me crazy.
Rauchen is offline
post #2 of 3 (permalink) Old 07-29-2009, 01:50 PM
robgigliotti's Avatar
Date registered: Feb 2009
If you dont find one I can sell you one for 1/2 of the new one, its used but I know it works. Does yours have the light on the end of it if you screw the button off?
1984 300sd -
1969 220d -
1997 Chevy Suburban -
robgigliotti is offline
post #3 of 3 (permalink) Old 08-12-2009, 12:16 AM
Date registered: Aug 2009
Vehicle: 1969 230/6 114-
My flasher went out as well and I didn't like the price of the replacement. I figured out how to rewire using 3 standard flashers with crimp on connectors (spade and bullets) that gives me turn signel and E flasher. If interested in going this route, get back in touch and I'll pull this section and color code a wireing diagram for your install. My is for a 230/6 114 but I'll label what the leads go to if yours are colored differently.
OK KId is offline
    Replacing Turn Signal Relay GreaseMonkey1986 W123 E,CE,D,CD,TD,TE Class 18 12-17-2015 11:40 AM
    Turn Signal Relay jmai W126 S,SE,SEC,SEL,SD,SDL Class 6 06-09-2012 04:40 PM
    W124-Is there a turn signal relay? NorCalSL W124 E,CE,D,TD Class 4 03-09-2008 08:16 AM
    Turn Signal Relay Minkoff W126 S,SE,SEC,SEL,SD,SDL Class 0 05-09-2006 10:29 AM
    Should the turn-signal relay be that silent? Guest (MBNZ) R/C107 SL/SLC Class 12 08-14-2005 07:57 PM
